Adding Columns to Standard Grid View
Sales Order Entry has ACTIONS>BUILD ORDER FROM HISTORY.
We would like to add some Part UDFs and Customer Part Numbers to that view. Can this be done without hacking into the base code that builds the data set?
There are a number of threads on this site that cover this question. That should give you a good start :slight_smile:
here is the video created by @josecgomez for Epicor 9, but same applicable for Epicor 10.
Thanks Surendra! I will try to apply this to my challenge. I really appreciate your direction, I know Jose is a wizard, but I had apparently not used the proper search terms when trying to find past threads on the subject. Regards, Rick
