Adding database field to existing Epicor Crystal Report
I think I have it working.
Karen Schoenung
Sent: Wednesday, March 21, 2012 2:43 PM
Subject: RE: [Vantage] Re: Adding database field to existing Epicor Crystal
Report
And, you will see there is a spot that shows the subreport (properties) that
you point it to the new XML - sorry, didn't think about a sub report
involved.
Behalf Of John Driggers
Sent: Wednesday, March 21, 2012 1:41 PM
Subject: Re: [Vantage] Re: Adding database field to existing Epicor Crystal
Report
Don't remove the old dataset. Go to 'Set DataSource Location' and point it
to the new XML file. This will update the schema and add/remove fields as
appropriate without messing with the existing report.
On Wed, Mar 21, 2012 at 2:28 PM, mike.numbers <mnumbers@...
<mailto:mnumbers%40cignys.com> > wrote:
> I am good upto the point of linking to the new XML file. I use
> Database - Database Expert - Create new Connections - Ado. Then remove
> the old ReportDataSet and replace it with the new ReportDataSet which
> does include Checkbox01. The problem is when I do this I loose among
> other fields, the subreport links. Is there another way to link the new
xml?
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , Karen
Schoenung <kschoenung@...> wrote:
> > It should be pretty easy...Copy the Crystal report to keep the
> > system
> one in place...Make a new report style, pointing to the new RDD and
> the copied report location. Print preview a PO choosing the new report
> style - this will give your new XML file, but still have the original
> Crystal report data...Then open your new copied report in Crystal and
> link to your XML file - which should now have the checkbox01
> field...Verify you see the field in your XML and then under your tables in
Crystal field explorer...
> Behalf Of mike.numbers
> > Sent: Wednesday, March 21, 2012 1:10 PM
> > Subject: [Vantage] Adding database field to existing Epicor Crystal
> Report
> > I need to add the checkbox01 from POHeader to the POForm (Purchase
> > Order
> Report). I can change the Report Data Definition for the POForm. But I
> can't figure out how to make the field show up in the Crystal report.
> My first attempt caused me to loose most of the form. Any help would
> be appreciated.
*John Driggers*
*High End Dev, System Design, Profit Drinking*
**:: 904.404.9233*
*:: waffqle@... <mailto:waffqle%40gmail.com> *
*:: NO FAXES*
I need to add the checkbox01 from POHeader to the POForm (Purchase Order Report). I can change the Report Data Definition for the POForm. But I can't figure out how to make the field show up in the Crystal report. My first attempt caused me to loose most of the form. Any help would be appreciated.
It should be pretty easy...Copy the Crystal report to keep the system one in place...Make a new report style, pointing to the new RDD and the copied report location. Print preview a PO choosing the new report style - this will give your new XML file, but still have the original Crystal report data...Then open your new copied report in Crystal and link to your XML file - which should now have the checkbox01 field...Verify you see the field in your XML and then under your tables in Crystal field explorer...
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of mike.numbers
Subject: [Vantage] Adding database field to existing Epicor Crystal Report
I am good upto the point of linking to the new XML file. I use Database - Database Expert - Create new Connections - Ado. Then remove the old ReportDataSet and replace it with the new ReportDataSet which does include Checkbox01. The problem is when I do this I loose among other fields, the subreport links. Is there another way to link the new xml?
> Report
> appreciated.
*John Driggers*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
And, you will see there is a spot that shows the subreport (properties) that you point it to the new XML - sorry, didn't think about a sub report involved.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of John Driggers
Subject: Re: [Vantage] Re: Adding database field to existing Epicor Crystal Report
Don't remove the old dataset. Go to 'Set DataSource Location' and point it to the new XML file. This will update the schema and add/remove fields as appropriate without messing with the existing report.
> > system
> Report
> > Order
> be appreciated.
*John Driggers*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
