# Adding fields into an EpiDataView for viewing purpose only
**URL:** <https://www.epiusers.help/t/adding-fields-into-an-epidataview-for-viewing-purpose-only/72260>\
**Category:** Epicor ERP 10\
**Tags:** e10\
**Created:** [October 28, 2020, 3:15am UTC](https://www.epiusers.help/t/adding-fields-into-an-epidataview-for-viewing-purpose-only/72260 "2020-10-28T03:15:39Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![Carson](https://www.epiusers.help/user_avatar/www.epiusers.help/carson/32/28741_2.png) [@Carson](https://www.epiusers.help/u/Carson)\
**Post date:** [October 28, 2020, 12:52pm UTC](https://www.epiusers.help/t/adding-fields-into-an-epidataview-for-viewing-purpose-only/72260/2 "2020-10-28T12:52:03Z")
</div>
Since you are adding it to the data table you are actually adding it to the dataset that is being saved back to the server. Those fields don’t exist and Epicor doesn’t like that. Here’s an example of adding it to just the grid without adding it to the data table.
> [@Add Fields to Epicor Custom Grid](https://www.epiusers.help/t/add-fields-to-epicor-custom-grid/48278/24):
> Here is the updated code that will work. You could probably use GetList or GetRows for this. GetList would get you some better performance. // \*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\* // Custom code for ResourceSchedForm // Created: 9/28/2018 8:47:46 AM // \*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\*\* using System; using System.ComponentModel; using System.Data; using System.Diagnostics; using System.Windows.Forms; using Erp.Adapters; using Erp.UI; using Ice.Lib; using Ice.Adapte…
_[View the full topic](https://www.epiusers.help/t/adding-fields-into-an-epidataview-for-viewing-purpose-only/72260)._
