Adding fields to Part Master Screen
Sandy here is how I have added items to part master screen.
Go to any part in part master. Double right click on a blank area on the screen. Click on Customize from the box that appears. A tool bar will pop up. Click on the type of field wanted. Click near where you want field located. Once placed adjust field to exact location.
Highlight the field then click EDIT on the main menu. Then click on control properties.
Select the next available field from the dropdown
Enter what you want to see as field text
Click OK, File-Save all frames, Yes, File, then Exit.
Hope this helps!
Paul E. Pachniak
Accounting Manager
Ace Precision Machining Corporation
Email: paul.pachniak@...
Phone: 1-262-252-4003 (ext 1114)
NOTICE: THIS MESSAGE CONTAINS THE PROPRIETARY AND CONFIDENTIAL INFORMATION OF ACE PRECISION MACHINING CORP. If you are an unintended recipient, immediately (1) delete all copies of this message and any attachments, and (2) contact the sender. If you are an intended recipient, you are prohibited from deleting or obstructing this or any other Ace Precision Machining Corp. proprietary or confidentiality designation that appears on this message or any attachments. All recipients are prohibited from reproducing, publishing or disclosing the contents of this message and any attachments to others, unless you first request and receive written permission from Ace Precision Machining Corp.
