Adding JobMtl Bin on Traveler without AMM module (no PartBin data)
We’d like to display the receiving bin location for Job Material on the Job Traveler.
I understand that data is in PartBin table but I believe that’s only true with the AMM module which we don’t currently have.
I can see the receiving location in the PartTran table and I’m able to aggregate in a BAQ to get bin totals by JobMtl, but I’m not sure whether this data can go on the existing report nor whether this is good practice.
  1. Is it true PartBin is not used absent AMM license?
  2. Is it possible to add a BAQ to an existing RDD/RDL? If so, should I bother?
I’m thinking the aggregate BAQ could become a perf issue as there are likely gazillions of records in PartTran once we go-live. True?
Would it make more sense to BPM copy receiving bin to a user field in JobMtl table instead?
Edit: Basically, we’re looking at going live without AMM and most of our material is order to job auto-issued and no material moves. As a result we lose visibility into JobMtl location and we’re looking at ways to close that gap without AMM.
If anyone has done the same, I’m open to suggestions.
TIA,
Josh
