Adding Last Transaction Date on Stock Status Report
--- In vantage@yahoogroups.com, "Elizabeth Hahn" <ehahn@...> wrote:
>Hi Liz,
I am using Crystal for this. The report is the original Stock Status
Report out of Vantage that I duplicated to add tables. I tried moving
the PartTran:TranDate field to the Group footer but the report came
up blank in a preview. I'll try it again, maybe I'm doing something
wrong.
Thanks again for your help.
Dave
> Hi Dave,
> I'm not sure how you have the report structured, but, if you put the
> transaction date from the PartTran table in the report footer, it
will
> only show the last date. Also if you put it in the report header,
it
> will only show the first transaction date. If you have groups, you
> would need to put it in the group footer. I was assuming you were
using
> Crystal, but now that I re-read your first post, you didn't say
that.
> Liz
Behalf
> Of Dave Eaton
> Sent: Wednesday, February 04, 2009 12:11 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Adding Last Transaction Date on Stock Status
> Report.
> Liz,
> I'm not sure I understand how that would work. Can you explian in a
> little more detail? Thanks for your help.
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
> "Elizabeth Hahn" <ehahn@> wrote:
> > You can also put the transaction date in the footer of the
report,
> it
> > should only show the last date.
> > Liz
> > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> [mailto:vantage@yahoogroups.com <mailto:vantage%
40yahoogroups.com> ] On
> Behalf
> > Of Jeff Stockard
> > Sent: Wednesday, February 04, 2009 10:03 AM
> > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > Subject: RE: [Vantage] Re: Adding Last Transaction Date on Stock
> Status
> > Report.
> > Have you tried reversing your link? If the Parent table is Part
and
> the
> > Child Table is PartTran, try making it the other way around.
> > [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> <mailto:vantage%
> > Behalf Of
> > Lynn
> > Sent: Wednesday, February 04, 2009 12:24 PM
Status
> > Report.
> > I see what you mean. It doesn't seem to matter if you put First,
> > Each, or Last. The resultant dataset still returns all records
from
> > the PartTran table.
> > I am also at a loss.
> > Lynn
> > <mailto:vantage%40yahoogroups.com> , "Dave
> > Eaton" <deaton@> wrote:
> > > I tried the "last" option in the relationship but it's still
> > showing
> > > all transaction dates instead of just the last transaction
date.
> We
> > > don't use Lot Tracking so that's not an option. Any other
> > > suggestions? I'm really stuck at this point.
40yahoogroups.com>
> > <mailto:vantage%40yahoogroups.com> , "Lynn"
> > <lynn.khalife@> wrote:
> > > > Try this:
> > > > When you add your Relationships for the PartTran table, go to
> the
> > > > Relationships--List tab (as opposed to the Relationships--
> Detail
> > > tab)
> > > > and find the column titled "Which Item" and type Last.
> > > > Refer to the following information pasted here from the
Vantage
> > > Help
> > > > on the "Which Item" column:
> > > > Which Item
> > > > The individual table records from which you will pull data.
> There
> > > are
> > > > three options you can enter in this field:
> > > > Each - All the table records will be pulled through this
> > > relationship.
> > > > First - Only the first table record will be pulled through
this
> > > > relationship.
> > > > Last - Only the last table record will be pulled through this
> > > > relationship.
> > > > Lynn
40yahoogroups.com>
> <mailto:vantage%
> 40yahoogroups.com>
> > "Dave Eaton" <deaton@> wrote:
> > > > > I'm trying to show the last transaction date on the Stock
> > Status
> > > > Report
> > > > > but I can't seem to find the field that displays it. So far
> > I've
> > > > added
> > > > > the PartTrans table to the report and add the TransDate
field
> > in
> > > > the
> > > > > report but it shows all transaction dates for each part
(huge
> > > > report).
> > > > > What can I do to show only the last transaction date for a
> part?
> > > > > Thanks in advance for your help.
> > > > > Dave
I'm trying to show the last transaction date on the Stock Status Report
but I can't seem to find the field that displays it. So far I've added
the PartTrans table to the report and add the TransDate field in the
report but it shows all transaction dates for each part (huge report).
What can I do to show only the last transaction date for a part?
Dave
Try this:
When you add your Relationships for the PartTran table, go to the
Relationships--List tab (as opposed to the Relationships--Detail tab)
Refer to the following information pasted here from the Vantage Help
Which Item
The individual table records from which you will pull data. There are
Each - All the table records will be pulled through this relationship.
First - Only the first table record will be pulled through this
relationship.
relationship.
Lynn
Report
added
the
report).
> Dave
I tried the "last" option in the relationship but it's still showing
all transaction dates instead of just the last transaction date. We
--- In vantage@yahoogroups.com, "Lynn" <lynn.khalife@...> wrote:
> Try this:
tab)
Help
> Which Item
are
relationship.
> relationship.
> relationship.
> Lynn
> Report
> added
> the
> report).
> > Dave
Each, or Last. The resultant dataset still returns all records from
the PartTran table.
Lynn
showing
> --- In vantage@yahoogroups.com, "Lynn" <lynn.khalife@> wrote:
> > Try this:
> tab)
> Help
> > Which Item
> are
> relationship.
> > relationship.
> > relationship.
> > Lynn
Status
> > Report
I've
> > added
in
> > the
> > report).
> > > Dave
Have you tried reversing your link? If the Parent table is Part and the
Lynn
Subject: [Vantage] Re: Adding Last Transaction Date on Stock Status Report.
the PartTran table.
Lynn
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Dave
showing
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Lynn"
> > Try this:
> tab)
> Help
> > Which Item
> are
> relationship.
> > relationship.
> > relationship.
> > Lynn
Status
> > Report
I've
> > added
in
> > the
> > report).
> > > Dave
You can also put the transaction date in the footer of the report, it
Liz
Of Jeff Stockard
Subject: RE: [Vantage] Re: Adding Last Transaction Date on Stock Status
Report.
Behalf Of
Lynn
Report.
the PartTran table.
Lynn
showing
> > Try this:
> tab)
> Help
> > Which Item
> are
> relationship.
> > relationship.
> > relationship.
> > Lynn
Status
> > Report
I've
> > added
in
> > the
> > report).
> > > Dave
The Part table is part of the original report so I can not be made a
child table. I can only make tables that I added child tables.
Thanks for the suggestion.
--- In vantage@yahoogroups.com, "Jeff Stockard" <jeff.stockard@...>
and the
Behalf Of
> Lynn
Report.
> the PartTran table.
> Lynn
> showing
We
> > > Try this:
the
Detail
> > tab)
> > Help
> > > Which Item
There
> > are
> > relationship.
> > > relationship.
> > > relationship.
> > > Lynn
> Status
> > > Report
> I've
> > > added
> in
> > > the
> > > report).
part?
> > > > Dave
Liz,
it
> Liz
Behalf
> Of Jeff Stockard
Status
> Report.
the
> Behalf Of
> Lynn
> Report.
> the PartTran table.
> Lynn
> showing
We
> > > Try this:
the
Detail
> > tab)
> > Help
> > > Which Item
There
> > are
> > relationship.
> > > relationship.
> > > relationship.
> > > Lynn
40yahoogroups.com>
> Status
> > > Report
> I've
> > > added
> in
> > > the
> > > report).
part?
> > > > Dave
Hi Dave,
transaction date from the PartTran table in the report footer, it will
only show the last date. Also if you put it in the report header, it
would need to put it in the group footer. I was assuming you were using
Crystal, but now that I re-read your first post, you didn't say that.
Liz
Of Dave Eaton
Report.
Liz,
it
> Liz
Behalf
> Of Jeff Stockard
Status
> Report.
the
<mailto:vantage%
> Behalf Of
> Lynn
> Report.
> the PartTran table.
> Lynn
> showing
We
> > > Try this:
the
Detail
> > tab)
> > Help
> > > Which Item
There
> > are
> > relationship.
> > > relationship.
> > > relationship.
> > > Lynn
<mailto:vantage%
40yahoogroups.com>
> Status
> > > Report
> I've
> > > added
> in
> > > the
> > > report).
part?
> > > > Dave
