Adding Part.Rev. Draw Number on the Purchase Order Form
Thank you so much .
it works.
--- In vantage@yahoogroups.com, <advantage@...> wrote:
> What version. How are you adding the PartRev table; through ODBC or
> modifying the RDD of the Report Style for the POForm.rpt?
> -----Original Message-----
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> advantage@...
> Sent: Wednesday, October 07, 2009 9:39 AM
> To: vantage@yahoogroups.com
> Subject: Re: [Vantage] adding Part.Rev. Draw Number on the Purchase Order
> Form
> Left outer join
> Sent from my Verizon Wireless BlackBerry
> From: "chllee72" <clee@alkenind. <mailto:clee%40alkenind.com> com>
> Date: Wed, 07 Oct 2009 13:22:02
> To: <vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com>
> Subject: [Vantage] adding Part.Rev. Draw Number on the Purchase Order Form
> Hi, expert.
> I wantto add Part.Rev.Draw# on the Purchase Order Crystal report on the
> Line. Since I needed to add PartRev.table to the PO Detail,
> I get the result only parts which has Part Rev. If there is any hardware
> which does not have rev. then PO form can not print.
> Is there any way I can put Part.Rev. Draw # on the Crystal report PO Form?
> Please help..
Hi, expert.
I wantto add Part.Rev.Draw# on the Purchase Order Crystal report on the Line. Since I needed to add PartRev.table to the PO Detail,
I get the result only parts which has Part Rev. If there is any hardware which does not have rev. then PO form can not print.
Please help..
Left outer join
To: <vantage@yahoogroups.com>
Hi, expert.
Please help..
advantage@...
Form
Left outer join
Hi, expert.
Please help..
