We use a + to indicate the end of the part and the beginning of the rev.
We have the same issue, in that we may want to stock different revs of the
same part.
Karen
"wendorff1"
<kelly.wendorff@s
cc-wi.com> To
Sent by: vantage@yahoogroups.com
vantage@yahoogrou cc
ps.com
Subject
[Vantage] Re: Adding Rev Level to
10/13/2006 02:41 Part Number
PM
Please respond to
vantage@yahoogrou
ps.com
I appreciate the feedback. The concern with having a single part
number is that once the part is received into FG's, we lose visibility
of the rev level. We have customers where it isn't uncommon to have
two different revisions of the same part either in our warehouse or
going through our shop.
same part.
Karen
"wendorff1"
<kelly.wendorff@s
cc-wi.com> To
ps.com
Subject
PM
Please respond to
vantage@yahoogrou
ps.com
--- In vantage@yahoogroups.com, "Shirley Graver" <shirleyg@...> wrote:
> Adding a rev to the end of your part number, imho, will cause you
> significantly more troubles in the long term. I'm assuming that you are
> proposing to add that as part of your part number entry. What
happens when
> the rev changes, a whole new part number? If you're just concerned
with rev
> visibility on paper, just tack the rev # field on to the end of the part
> number field. A good part numbering scheme won't contain any
variable that
> changes or might change, ever.
> Shirley Graver
> Sys Admin
> Rubber Associates.
> _____
Behalf Of
> wendorff1
> Sent: Friday, October 13, 2006 12:46 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Adding Rev Level to Part Number
> We are considering adding the Revision level as a suffix to our
> manufactured part number (to give us visibility of Rev Level in
> Finished Good inventory).
> The question we are having is what character to use to designate the
> end of the part number and the beginning of the Rev Level.
> We are considering using the underscore ( _ ).
> Ex: xxx-xxxx_01
> It appears that Vantage has no problem with the underscore character,
> does anyone forsee problems with barcoding (Dataworks 39) or in any
> other situation?
> Any feedback is appreciated!
> Thanks,
> Kelly
