Adding Table To Report Definition and Crystal
Dear Paul:
It sounds like you are still missing a few steps of this process.
There is an answerbook on the MyEpicWeb page on the Epicor website.
AnswerBook # 4778MPS, "CR Modifying a Crystal Report form in V8.xx"
After you modify your data definition and report style, then you need
to run that Report Style by Print-Pre-viewing a form in Vantage in
order to generate a new .xml file based upon your newly-modified Data
Definition.
Then you need to open up your Crystal Report Packing Slip form and
complete several steps in order to tell Crystal to use the new .xml
file.
It is important that the steps in the Answerbook be completely
followed in proper order. If you follow this Answerbook, you
shouldn't have any trouble adding anything you want to your Packing
Slip.
Lynn
--- In vantage@yahoogroups.com, "Paul" <chaosavy@...> wrote:
> I'm actually working with the packing slip form, I tried this
> (linking terms) yesterday and get no data once I try to get data
out
> of the terms.description field.
> I don't get how linking works in these reports, in any "regular"
> crystal report it would easily work how you describe and how I did
> it, linking shipdtl.company to terms.company and
> shipdtl.ordernum_termscode to terms.code, but once done in these
> crystal repots it returns no data. So strange, why isn't this a no
> brainer?
> --- In vantage@yahoogroups.com, "Jim Frice" <Jim.Frice@> wrote:
> > Now link from the terms code on the QuoteHed table to the Terms
> table to
> > be able to get the terms description.
> > Jim
> > ________________________________
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
> Behalf
> > Of Paul
> > Sent: Monday, November 24, 2008 4:19 PM
> > Subject: [Vantage] Re: Adding Table To Report Definition and
Crystal
> > This post helped me a bunch, had no idea about the "linked tables"
> > Although it didn't quite give me what I want (I want the terms
> > description, it gave me a terms code) at least its something.
> > thank you
> > --- In vantage@yahoogroups.com <mailto:vantage%
> 40yahoogroups.com> , "Vic
> > Drecchio" <vic.drecchio@>
> > wrote:
> > > Chris,
> > > You're making this more difficult then it needs to be. :-)
> > > Finally the Epicorian developers thought ahead slightly to
> > proactively
> > > support things like this....it's called Linked Tables.
> > > Quickly:
> > > Start from scratch; copy the default QuotForm RDD (report data
> def)
> > to
> > > something else.
> > > Open your newly copied RDD and click on the Report Table tab.
> > > Click on the List tab.
> > > Click on the QuoteHed Table.
> > > Now click on the Linked Tables tab. (options of linked tables
> > change
> > > for each table you click on in the RDD).
> > > Look on the left side of the Linked tables tab; you should
> > see "Lookup
> > > Available" and see 'ShipToNum' as a choice. 'ShipToNum' is your
> > ShipTo
> > > table. Why they didn't call it that, I'm not sure....
> > > Bring it over to the right side. Now click on the Description
> > Fields
> > > tab.
> > > In the dropdown box, select ShipToNum.
> > > Bring over the fields you want.
> > > Save.
> > > Now when you run this RDD, in the exported XML, these fields
will
> be
> > > added to the "QuoteHed" table's list of fields prefixed by
> > > "ShipToNum_{yourfield}.
> > > 80% of the time these Linked Tables are available. It is much
> > easier
> > > than setting up a relationship and adding a table. And then
> having
> > to
> > > duplicate in Crystal.
> > > Good luck.
> > > Vic Drecchio
> > > ERP Administrator
> > > TIMCO Aviation Services
> > > Greensboro, NC
> > > Email: vic.drecchio@
> > > Office: 336.668.4410 x3091
> > > Mobile: 704.530.3092
> > > -----Original Message-----
> > > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > [mailto:vantage@yahoogroups.com <mailto:vantage%
> 40yahoogroups.com> ] On
> > Behalf
> > > Of Chris Thompson
> > > Sent: Tuesday, November 11, 2008 9:54 AM
> > > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > > Subject: Re: [Vantage] Adding Table To Report Definition and
> Crystal
> > > Hi, We are on 8.03.404.
> > > Thanks
> > > From: Charles Carden <shadowcar1449@>
> > > Sent: Tuesday, November 11, 2008 2:24:22 PM
> Crystal
> > > What version of Vantage are you on? This is critical since the
> > ability
> > > to add tables and retrieve data was not there is some of the
older
> > > versions.
> > > ----- Original Message -----
> > > From: Chris Thompson
> > > To: vantage@yahoogroups .com
> > > Sent: Tuesday, November 11, 2008 8:10 AM
> > > Subject: [Vantage] Adding Table To Report Definition and Crystal
> > > Hi,
> > > I am modifying our Quote in Crystal and I need to add the 'Ship
> To'
> > > address of the customer on the Crystal form.
> > > As standard (even with all excluded fields included), Vantage
> > doesn't
> > > export this information in the .xml.
> > > I assume I need to add a Table for ShipTo in the Data
Definition
> for
> > > Quotes.
> > > I have done this, and Added a new Relationship (Parent Table:
> > Customer,
> > > Key: Blank, Child Table: ShipTo).
> > > For the Relationship Fields I have added Parent Field Name:
> > ShipToNum,
> > > Child Field Name: ShipToNum.
> > > In Relationship | List, I have said WhichItem: EACH.
> > > I have then ran the report to creat the .xml.
> > > In Crystal I have ser the Datasource Location and found the
> > latest .xml
> > > file.
> > > The ShipTo table appears in the new DataSet. I have selected
the
> > Report
> > > Dataset headers in existing/new and clicked update.
> > > It doesn't add the new table (ShipTo) to the new Report Dataset.
> > > I CAN add it manually in Database expert and then add a link
> between
> > > Customer and ShipTo where there is a link between CustNum,
> Customer
> > and
> > > ShipToID.
> > > I then add i.e. Address 1,2 and 3 from the ShipTo table to my
> > report,
> > > save, and preview my new Quote (print preview in Vantage), and
it
> > shows
> > > a blank form with no data (only borders etc).
> > > If I remove the fields from Address 1,2 and 3 and then save and
> > print
> > > preview the report, all data is there (with the exception of
the
> > ShipTo
> > > data fields (which I removed).
> > > Does anyone know where I am going wrong??
> > > Any help greatly appreciated.
> > > Cheers,
> > > CHRIS THOMPSON
> > > Charles Carden
> > > IT Manager
> > > Manitex, Inc.
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note:
You
> > must
> > > have already linked your email address to a yahoo id to enable
> > access. )
> > > (1) To access the Files Section of our Yahoo!Group for Report
> > Builder
> > > and Crystal Reports and other 'goodies', please goto:
> > > http://groups.yahoo.com/group/vantage/files/.
> > <http://groups.yahoo.com/group/vantage/files/.>
> > > (2) To search through old msg's goto:
> > > http://groups.yahoo.com/group/vantage/messages
> > <http://groups.yahoo.com/group/vantage/messages>
> > > (3) To view links to Vendors that provide Vantage services goto:
> > > http://groups.yahoo.com/group/vantage/linksYahoo
> > <http://groups.yahoo.com/group/vantage/linksYahoo> ! Groups Links
Hi,
I am modifying our Quote in Crystal and I need to add the 'Ship To' address of the customer on the Crystal form.
As standard (even with all excluded fields included), Vantage doesn't export this information in the .xml.
I assume I need to add a Table for ShipTo in the Data Definition for Quotes.
I have done this, and Added a new Relationship (Parent Table: Customer, Key: Blank, Child Table: ShipTo).
For the Relationship Fields I have added Parent Field Name: ShipToNum, Child Field Name: ShipToNum.
In Crystal I have ser the Datasource Location and found the latest .xml file.
The ShipTo table appears in the new DataSet. I have selected the Report Dataset headers in existing/new and clicked update.
I CAN add it manually in Database expert and then add a link between Customer and ShipTo where there is a link between CustNum, Customer and ShipToID.
I then add i.e. Address 1,2 and 3 from the ShipTo table to my report, save, and preview my new Quote (print preview in Vantage), and it shows a blank form with no data (only borders etc).
If I remove the fields from Address 1,2 and 3 and then save and print preview the report, all data is there (with the exception of the ShipTo data fields (which I removed).
Cheers,
CHRIS THOMPSONÂ
I have encountered the 'blank' report condition when adding tables.
If I Linked to the new table from existing report data it would
happen. If I linked from the new table to the exisiting data it works.
try reversing the direction of the links to the new table.
bw
--- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@...>
wrote:
> Hi,
for Quotes.
latest .xml file.
> Cheers,
> CHRIS THOMPSONÂ
What version of Vantage are you on? This is critical since the ability to add tables and retrieve data was not there is some of the older versions.
Hi,
Cheers,
CHRIS THOMPSON
Charles Carden
IT Manager
Manitex, Inc.
Subject: Re: [Vantage] Adding Table To Report Definition and Crystal
Hi,
Cheers,
CHRIS THOMPSON
Charles Carden
IT Manager
Manitex, Inc.
Chris,
Finally the Epicorian developers thought ahead slightly to proactively
Quickly:
Start from scratch; copy the default QuotForm RDD (report data def) to
something else.
Now click on the Linked Tables tab. (options of linked tables change
Look on the left side of the Linked tables tab; you should see "Lookup
Available" and see 'ShipToNum' as a choice. 'ShipToNum' is your ShipTo
Bring it over to the right side. Now click on the Description Fields
tab.
Save.
Now when you run this RDD, in the exported XML, these fields will be
80% of the time these Linked Tables are available. It is much easier
than setting up a relationship and adding a table. And then having to
Good luck.
Vic Drecchio
ERP Administrator
Greensboro, NC
Email: vic.drecchio@...
Of Chris Thompson
versions.
Hi,
Quotes.
file.
ShipToID.
Cheers,
CHRIS THOMPSON
Charles Carden
IT Manager
Manitex, Inc.
Chris:
Vic's suggestion of using the Epicor-provdided linked tables is the
best way to go.
However, for future reference, I don't see below where you remembered
to establish the relationship between customer.company =
shipto.company.
The fieldname Company exists in every Vantage table; and for every
relationship you add, ParentTable.Company = ChildTable.Company needs
to exist.
Lynn
wrote:
> Hi,
for Quotes.
latest .xml file.
> Cheers,
> CHRIS THOMPSONÂ
And one further note - even though you won't be using the 'key'
fields on the report, include them in the data being sent to the
report so you can link the tables in the dabase expert in Crystal.
--- In vantage@yahoogroups.com, "Lynn" <lynn.khalife@...> wrote:
> Chris:
> best way to go.
remembered
> shipto.company.
needs
> to exist.
> Lynn
> --- In vantage@yahoogroups.com, Chris Thompson <chriselectrix@>
> wrote:
> > Hi,
To'
> for Quotes.
> latest .xml file.
> > Cheers,
> > CHRIS THOMPSONÂ
thank you
--- In vantage@yahoogroups.com, "Vic Drecchio" <vic.drecchio@...>
wrote:
> Chris,
proactively
> Quickly:
to
> something else.
change
see "Lookup
ShipTo
Fields
> tab.
> Save.
easier
to
> Good luck.
> Vic Drecchio
> ERP Administrator
> Greensboro, NC
Behalf
> Of Chris Thompson
> Thanks
> From: Charles Carden <shadowcar1449@...>
ability
> versions.
> Hi,
doesn't
> Quotes.
Customer,
ShipToNum,
latest .xml
> file.
Report
and
> ShipToID.
report,
shows
print
ShipTo
> Cheers,
> CHRIS THOMPSON
> Charles Carden
> IT Manager
> Manitex, Inc.
must
access. )
Builder
Now link from the terms code on the QuoteHed table to the Terms table to
Jim
Of Paul
Subject: [Vantage] Re: Adding Table To Report Definition and Crystal
thank you
--- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , "Vic
wrote:
> Chris,
proactively
> Quickly:
to
> something else.
change
see "Lookup
ShipTo
Fields
> tab.
> Save.
easier
to
> Good luck.
> Vic Drecchio
> ERP Administrator
> Greensboro, NC
Behalf
> Of Chris Thompson
> Thanks
ability
> versions.
> Hi,
doesn't
> Quotes.
Customer,
ShipToNum,
latest .xml
> file.
Report
and
> ShipToID.
report,
shows
print
ShipTo
> Cheers,
> CHRIS THOMPSON
> Charles Carden
> IT Manager
> Manitex, Inc.
must
access. )
Builder
(linking terms) yesterday and get no data once I try to get data out
brainer?
table to
> Jim
Behalf
> Of Paul
> thank you
> wrote:
> > Chris,
> proactively
> > Quickly:
def)
> to
> > something else.
> change
> see "Lookup
> ShipTo
> Fields
> > tab.
> > Save.
be
> easier
having
> to
> > Good luck.
> > Vic Drecchio
> > ERP Administrator
> > Greensboro, NC
> Behalf
> > Of Chris Thompson
Crystal
> > Thanks
Crystal
> ability
> > versions.
> > Hi,
To'
> doesn't
for
> > Quotes.
> Customer,
> ShipToNum,
> latest .xml
> > file.
> Report
between
Customer
> and
> > ShipToID.
> report,
> shows
> print
> ShipTo
> > Cheers,
> > CHRIS THOMPSON
> > Charles Carden
> > IT Manager
> > Manitex, Inc.
> must
> access. )
> Builder
