We had so many problems on 408B with different applications that we went up to 4.09A. Now we're debugging their latest patch, but it seems to have fixed a lot of problems from 408B.
--- In vantage@yahoogroups.com, "Brian W. Spolarich " <bspolarich@...> wrote:
> Since upgrading from 405 to 408B we've taken a major step backwards in
> our ability to use the Adjust WIP program.
> Previously we could use Job Adjustment and WIP Adjustment to manually
> adjust job quantities and WIP locations to match reality (typically when
> an operator mis-reported a quantity, etc.) and we could do this at any
> arbitrary job operation.
> Now WIP Adjustment is much more restrictive about which operations are
> permitted to be adjusted. The workaround which we've identified is
> quite laborious (not sure I can describe it since this is outside of my
> detailed understanding of Vantage).
> Just curious if anyone else has been burned in general by this.
> The answer we've gotten so far is 'works as designed' although we're
> making some progress at least identifying that there has been a change
> and trying to understand the purpose behind the change.
> -bws
> Brian W. Spolarich ~ Manager, Information Services ~ Advanced Photonix /
> Picometrix
> bspolarich@...
> <mailto:bspolarich@...> ~ 734-864-5618 ~
> www.advancedphotonix.com <http://www.advancedphotonix.com>
