ADOBD Connection PartDescription is blank
Try
Select substring(PartDescription,1,255) as partDescription from ...
On Jun 11, 2011 6:10 PM, "randyweb" <weber.randy@...> wrote:
Epicor 9.05.604a
I am using Excel VBA ADODB connection to SQL server to get part data. The description field comes up blank. Here is my query:
.Open "SELECT Company, PartNum, PartDescription, ClassId,IUM FROM Part"
Sheets("Sheet3").Range("A1").CopyFromRecordset rsPubs
Is does not return any errors, but the third column where the PartDescription should be is blank.
Any ideas?
Randy Weber
Rayotek Scientific
What happens if you loop through the descriptions instead of using the
CopyFromRecordset method?
While not rsPubs.eof
debug.print rsPubs("PartDescription")
Wend
Mark W.
On Sat, Jun 11, 2011 at 3:16 PM, randyweb <weber.randy@...> wrote:
> Epicor 9.05.604a
> Any ideas?
> Randy Weber
> Rayotek Scientific
Mark,
The same thing happens. I think it is because the field type is adoVarLongChar and holds up to 1,000 characters, though we don't have any longer than about 200.
It's driving me crazy. I was able to display the PartDescription with ODBC and MS Query, but I cannot get it using code, which I need for this project.
Thanks for trying.
Randy
> Wend
> Mark W.
> > Epicor 9.05.604a
> > Any ideas?
> > Randy Weber
> > Rayotek Scientific
