Advanced Customization: Code Examples?
UPDATE:
Below is kinda what I'm trying to accomplish:
-----------------------------BEGIN
Private Sub txtEpiCustom1_Leave(ByVal Sender As Object, ByVal Args As
System.EventArgs) Handles txtEpiCustom1.Leave
'// ** Place Event Handling Code Here **
If (txtEpiCustom1.Text <> String.Empty) Then
'// Do Search (listLookup)
Dim recordSelected As Boolean
Dim showSearch As Boolean = False
Dim whereClause As String = "Key1 = '" & txtEpiCustom1.Text & "'"
'// Call Search Function
Dim dsComments As DataSet = SearchFunctions.listLookup
(SalesOrderForm, "UD01Adapter", recordSelected, showSearch,
whereClause)
'// check to see if DataSet is not null and that it
'// contains at least 1 DataTable
If (recordSelected = True) Then
'// get a reference to the OrderDtl EpiDataView
Dim edvOrderDtl As EpiDataView = CType(oTrans.EpiDataViews
("OrderDtl"), EpiDataView)
'// set the OrderComment field to value returned by search
edvOrderDtl.dataView(edvOrderDtl.Row)("OrderComment") =
dsComments.Tables(0).Rows(0)("Character01")
'// notify bound control(s) of data change
edvOrderDtl.Notify( New EpiNotifyArgs(SalesOrderForm,
edvOrderDtl.Row, edvOrderDtl.Column))
End If
End If
'// Set Text to Empty String
txtEpiCustom1.Text = String.Empty
End Sub
----------------------------------END
--- In vantage@yahoogroups.com, "sanfranc415" <sanfranc415@...> wrote:
> Hello,
> I'd like it if somebody could post some examples of advances
> customizations they've done. I'm trying to customize Customer
Shipment
> to search Operation Codes from Custombox1. Once the LostFocus
event is
> triggered, CustomBox2 will populate with the extended description
of
> the code you enter in CustomBox1.
> Thanks,
> --SF
Hello,
customizations they've done. I'm trying to customize Customer Shipment
to search Operation Codes from Custombox1. Once the LostFocus event is
triggered, CustomBox2 will populate with the extended description of
--SF
