Advanced Customization Scenario
I am little disappointed that no one was answer my question. I think
that it's really simple to run 4GL procedure from within UD form.
I was trying to open a Open4GL session but there is a problem with
namespaces (This is my guess).
Dim ProgressSession As Progress.Open4GL.DynamicAPI.Session = Nothing
I supposed to use a
Imports Progress
but it doesn't exist with some reasons.
Any help will be appreciated.
Grzegorz Szczepañski
--- In vantage@yahoogroups.com, "Grzegorz (phoenix_)" <phoenix_@...>
wrote:
> Robert,
> I am still sustaining my previous statement - "This question is not for
> resolving the specific issue. It's for learning purposes". I know the
> things I would like to learn. I don't want to create a several pages
> message without answer. People don't like to read a message if there is
> a lot of text inside. Therefore my idea was to build scenario with
> elements I would like to learn. After that I want to create a *.odt so
> everyone who want to learn the same things as me will be able to use
> this example.
> You were mentioned about Epicor Support, usually they answers are like
> below:
> "These questions are consulting/education questions which should be
> chargeable"
> I want to do the following things in my scenario:
> 1. The points 1&2 described previously. I don't know if BAQ Search is
> still usefull here?
> 2. Be able to save the DataSet to UD table
> 3. Be able to have button that let me RUN a progress procedure, with
> possibility to pass a parameter to this procedure (query etc)
> I hope that my questions are not theoretical/hypothetically anymore :)
> and that you or someone else will be able to help me.
> regards
> Dnia 26-11-2008 o godz. 6:50 Robert Brown napisa³(a):
> > Elementy potencjalnie niebezpieczne zosta³y zablokowane.
> > Grzegorz,
> > Ah... So this IS a real world need and not just "This question is not
> for resolving the specific issue. It's for learning purposes".
> > You don't say in your original email what you are really trying to do
> (or if you did - sorry - I'm just not following it & I don't get it).
> > In general: Your UD Key# fields (perhaps not all) need to be
populated
> with data to enable the joins you need to Part & PartLot. What those
> needs are, I won't even hazard a guess unless you can describe a real
> scenario.
> > (That's why they are UD tables - so you can design them for use to
join
> them as YOU need to native tables.)
> > Does that answer the hypothetical question hypothetically enough?
> > :) - Sorry it's one am and I'm VERY tired... Just teasing. No offense
> meant so I hope none taken. I'd be happy to take a stab at a better
> answer with more info from you.
> > (Still can't believe Epicor support or the knowledge base on their
> website couldn't provide you more definitive resolution ?!?!?)
> > Rob
> > --- On Tue, 11/25/08, phoenix <phoenix_@...> wrote:
> > From: phoenix <phoenix_@...>
> > Subject: Re: [Vantage] Advanced Customization Scenario
> > Date: Tuesday, November 25, 2008, 1:33 PM
> > Robert,
> > so the answer is BAQ Search. I was thinking about it. But also I was
> > trying to avoid this :). The reason for it is that the next step will
> > be fill out the Key1, Key2, Key3, Key4 fields with results from
'search
> > form'. How can I connect results from 'search form' with this fields?
> > If you know that please answer and I will update the scenario and I
> > will start creating the *.odt file for the people.
> > Dnia Tue, 25 Nov :14: (PST)
> > Robert Brown <robertb_versa@ yahoo.com> napisa³(a):
> > > No mystery to #2... Can't believe support couldn't provide immediate
> > > resolution.
> > > Write a BAQ against UD20, Part & PartLot. You will have to manually
> > > specify the column joins and, depending upon how you are using UD20,
> > > determine if the joins should be inner or outer for best effect.
> > > Make the BAQ shared (and perhaps Global) & save the BAQ after
testing.
> > > Reopen the BAQ. In the BAQ Search tab of the editor, move all of
your
> > > available (left pane) Available "Like" columns to the right pane
(BAQ
> > > Search "Like columns) and resave. (Backup/export to xml for good
> > > measure.)
> > > In your UD20 app, the BAQ should now be available as a BAQ search in
> > > the search window.
> > > If you want, make it a named search and make it the defualt search
> > > for your app.
> > > Rob
> > > --- On Tue, 11/25/08, tomojmail <phoenix_@wp. pl> wrote:
> > > From: tomojmail <phoenix_@wp. pl>
> > > Subject: [Vantage] Advanced Customization Scenario
> > > To: vantage@yahoogroups .com
> > > Date: Tuesday, November 25, 2008, 9:32 AM
> > > This question is not for resolving the specific issue. It's for
> > > learning purposes.
> > > Lot of people from this list can have benefits from the answers that
> > > let us resolve the following scenario:
> > > 1. We are using one of the Epicor.Mfg.BO. UDxx.dll as starting point
> > > of our scenario. The default 'form' have two sheets 'Detail' and
> > > 'List' sheet.
> > > TIP/RESOLUTION. To be able to use 'UD20 Maintenance Form' you
need to
> > > use 'Menu Maintenance' application, then ADD 'new menu' with the
> > > following settings:
> > > Program Type - Menu item
> > > Program - Epicor.Mfg.UI. UD20Entry. dll
> > > For the rest of the settings you can choose whatever you need.
> > > 2. When 'search button' is pressed it opens the 'search form' in
> > > default it consist of all elements from 'UD20 dataView'. I would
like
> > > to change this 'search form' to display the information from 2
tables
> > > joined by my rules (query).
> > > Table1: Part
> > > Table2: PartLot
> > > Colums for displaying: Part.PartDescriptio n, Part.CostMethod,
> > > PartLot.LotNum, PartLot.OnHand
> > > The 'Search Query': Select PT.PartDescription, PT.CostMethod,
> > > PL.LotNum, PL.OnHand from pub.Part as PT join pub.PartLot as PL on
> > > PT.PartNum = PL.PartNum where PT.PartDescription = PARAMETER
> > > The PARAMETER should be a 'Starting At' from 'search form'
> > > TIP/RESOLUTION. Waiting for answers.
> > > To be able to complete point 2 we need to answer the following:
> > > (please correct me if I am wrong)
> > > A) (UNANSWERED) Create New dataView or assign the 'search
results' to
> > > existing fields of 'UD20 dataView' - I prefer to create a new
dataView
> > > (it will help to learn of creation and manipulation of dataViews)
> > > B) (UNANSWERED) Send somehow a 'Search Query' to database.
> > > C) (UNANSWERED) Aquire results from database and assign them to
> > > columns in 'search form'
> > > Currently I am waiting for answers for A, B and C. to resolve point
> > > number 2. I will be maintaining the whole scenario. Moreover I will
> > > create a *.doc or *.odt with screenshots with the answers for
> > > particular steps and it will be available from 'files' section
of this
> > > group. To be able to do this I will need a community to
cooperate. So
> > > people - please answer.
> Fascynuj±cy labirynt Carlosa Ruiza Zafona, autora Cienia wiatru:
> ¶wiat Barcelony, mroczne sekrety i Cmentarz Zapomnianych Ksi±¿ek w
> najnowszej powie¶ci pt. "Gra anio³a"!
http://klik.wp.pl/?adr=http%3A%2F%2Fcorto.www.wp.pl%2Fas%2Fgraaniola.html&sid=569
learning purposes.
1. We are using one of the Epicor.Mfg.BO.UDxx.dll as starting point of
our scenario. The default 'form' have two sheets 'Detail' and 'List'
sheet.
TIP/RESOLUTION. To be able to use 'UD20 Maintenance Form' you need to
following settings:
Program - Epicor.Mfg.UI.UD20Entry.dll
default it consist of all elements from 'UD20 dataView'. I would like
to change this 'search form' to display the information from 2 tables
Table1: Part
Table2: PartLot
Colums for displaying: Part.PartDescription, Part.CostMethod,
A) (UNANSWERED) Create New dataView or assign the 'search results' to
existing fields of 'UD20 dataView' - I prefer to create a new dataView
particular steps and it will be available from 'files' section of this
group. To be able to do this I will need a community to cooperate. So
No mystery to #2... Can't believe support couldn't provide immediate resolution.
Write a BAQ against UD20, Part & PartLot. You will have to manually specify the column joins and, depending upon how you are using UD20, determine if the joins should be inner or outer for best effect.
Make the BAQ shared (and perhaps Global) & save the BAQ after testing.
Reopen the BAQ. In the BAQ Search tab of the editor, move all of your available (left pane) Available "Like" columns to the right pane (BAQ Search "Like columns) and resave. (Backup/export to xml for good measure.)
In your UD20 app, the BAQ should now be available as a BAQ search in the search window.
If you want, make it a named search and make it the defualt search for your app.
Rob
learning purposes.
1. We are using one of the Epicor.Mfg.BO. UDxx.dll as starting point of
sheet.
following settings:
Table1: Part
Table2: PartLot
Robert,
be fill out the Key1, Key2, Key3, Key4 fields with results from 'search
Grzegorz Szczepański
Dnia Tue, 25 Nov 2008 07:14:19 -0800 (PST)
> resolution.
> measure.)
> the search window.
> for your app.
> Rob
> From: tomojmail <phoenix_@...>
> learning purposes.
> 'List' sheet.
> following settings:
> Table1: Part
> Table2: PartLot
Grzegorz,
Ah... So this IS a real world need and not just "This question is not for resolving the specific issue. It's for learning purposes".
You don't say in your original email what you are really trying to do (or if you did - sorry - I'm just not following it & I don't get it).
In general: Your UD Key# fields (perhaps not all) need to be populated with data to enable the joins you need to Part & PartLot. What those needs are, I won't even hazard a guess unless you can describe a real scenario.
(That's why they are UD tables - so you can design them for use to join them as YOU need to native tables.)
:) - Sorry it's one am and I'm VERY tired... Just teasing. No offense meant so I hope none taken. I'd be happy to take a stab at a better answer with more info from you.
(Still can't believe Epicor support or the knowledge base on their website couldn't provide you more definitive resolution ?!?!?)
Rob
Robert,
> resolution.
> measure.)
> the search window.
> for your app.
> Rob
> learning purposes.
> 'List' sheet.
> following settings:
> Table1: Part
> Table2: PartLot
Robert,
this example.
below:
chargeable"
still usefull here?
regards
Dnia 26-11-2008 o godz. 6:50 Robert Brown napisał(a):
> Elementy potencjalnie niebezpieczne zostały zablokowane.
> Grzegorz,
scenario.
> Rob
> Robert,
> > resolution.
> > measure.)
> > the search window.
> > for your app.
> > Rob
> > learning purposes.
> > 'List' sheet.
> > following settings:
> > Table1: Part
> > Table2: PartLot
> > Grzegorz SzczepaĂąski
FascynujÄ…cy labirynt Carlosa Ruiza Zafona, autora Cienia wiatru:
świat Barcelony, mroczne sekrety i Cmentarz Zapomnianych Książek w
najnowszej powieści pt. "Gra anioła"!
