Alert On Shipment CheckBox
There should be a method called. Do a trace. You should be able to do this
via BPM very easily either on a get new or update - not sure what the exact
method name is called.
gmack110256
Sent: Wednesday, April 07, 2010 9:15 AM
Subject: [Vantage] Alert On Shipment CheckBox
I am trying to figure out if there is a way to get the "Alert on Shipment"
checkbox on the Sales Order
Entry form to default always checked.
Is there a way to do it thru a wizard set up on the Order Entry Form
when the form is closed or is there a way to set the checkbox as to always
checked?
Thank You
Gene
I am trying to figure out if there is a way to get the "Alert on Shipment" checkbox on the Sales Order
when the form is closed or is there a way to set the checkbox as to always checked?
Thank You
Gene
