Alert When creating a new product
Hello can anyone help when creating a new part a lot of people keep forgetting to put a weight or commodity code in which affects our invoice run can anyone put a prompt that upon save there must be a commodity code or weight over 0.4kg ?
For the Commodity Code, I think the best way to do that is to use Extended Properties under System Maintenance. Just pull up the table and column and mar it as required and they will not be able to save without entering something.
For the weight, you will have to do a BPM.
