OR mark it as issued complete (even though zero qty issued). In 8.03.4xx you can customize job entry to allow you to manually mark mtl details as issued complete. MRP and netting screens (so far) respect that flag.
It'll cause a job cost variance (but apparently something was wrong to begin with - so it should).
You may be able to accomplish same with job completion/closing program or job cost adjustment but this works for us w/out opening up these programs to people that should really have access.
Rob
--- Original Message ---
Sent:Fri 9/10/10 8:36 pm
To:<vantage@yahoogroups.com>
Subj:[Vantage] Allowing the Qty on a Job to be Zero a solution?
Good Day:
RE: Allowing the Qty on a Job to be Zero
Sun Is on M2K 7.0 SP 5 (Informix) but,
Going to: Epicor 9, 9.05.600B.2 SQL (go live date is 11/1/10)
In our testing we found that you cannot remove a Component from a
Job if there was any 'activity'.
One solution would be to change the qty to zero; but E9 does not
allow that. There is a request into Epicor to allow the zero qty. It
would be helpful if others would also ask for it. So, if you agree,
please advise your CAM or consultant and add your name to the list. The
more on the list, the faster it gets done.
Apparently the other solution is to CHANGE the Part# to a 'dummy'
part#. Does anyone have any experience with that?
len.hartka@...
<blocked::blocked::mailto:len.hartka@...>
Sun Automation Group
Celebrating
25 Years of Service
to the Corrugated Industry
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
Rob
Good Day:
len.hartka@...
Celebrating
25 Years of Service
