Another Enhancement Request for all you progres s programmers o
Been there, did that, it worked!
The key was the CAPS function.
(And tech support said it couldn't be done!)
Greg Krumrey, Information Manager, Patriot Machine, Inc.
Voice: 636-940-1776 x 130, fax: 636-940-8933
email: mailto:greg.krumrey@...
Alt: mailto:greg@... Web: www.patriot-machine.com
Sent: Friday, August 02, 2002 9:01 AM
Subject: RE: [Vantage] Re: Another Enhancement Request for all you progress
programmers out there...
I have used the following code to test passwords and the encode function. It
works up to 4.0.
Def Var TmpPassWd Like UserFile.Password.
For Each UserFile:
TmpPassWd = "Enter Your password Here".
TmpPassWd = encode(Caps(tmppasswd)).
If Password = Tmppasswd Then
Display DcdUserId
Name
Password
TmpPassWd.
DEFINE VARIABLE password AS CHARACTER FORMAT "x(16)".
DEFINE VARIABLE id AS CHARACTER FORMAT "x(12)".
DEFINE VARIABLE codedpwrd AS CHARACTER FORMAT "x(16)".
SET id LABEL "Enter user id" password LABEL
"Enter password" BLANK WITH CENTERED SIDE-LABELS.
codedpwrd = ENCODE(password).
DISPLAY codedpwrd LABEL "Encoded password".
Jim
Sent: Friday, August 02, 2002 7:53 AM
To: 'vantage@yahoogroups.com'
Been There, Tried That, Didn't work.
When I called Epicor, they said Vantage uses it's own ENCODE algorithm that
has nothing to do with ENCODE() in progress or report builder (which are the
same).
If Epicor added it's encode as an algorithm that would solve my problem.
If they added a write trigger to encode the password a second time, using
progress ENCODE and placed it next to the PassWord field in UserFile
(PassWord2?), that would fix the problem.
If they wanted to really secure it, they could have a routine, that, when
called, would prompt the user for the User ID and Password, and return a
Login Success (True/False) and a Vantage ID. This is what I asked for.
While I see the benefits of password auditing, I would think the risks would
be much higher. In the hands of a hacker, a list of Vantage passwords would
be a gold mine. Besides, it is a possibility that there is no
inverse-vantage-encode. If it was a one-way routine, they would just encode
the password you typed in, and compare it to the encoded value in UserFile.
It's been a while, but I think this is how Unix works (with a twist of
Salt).
If the password export were to be added, it should probably require a module
that it activated only with the company's owner's password (or something
like that). Otherwise, a disgruntled system manager could keep this list as
an ace-in-the-hole in the event they were fired.
Finally, being a system manager and not knowing anyone else's passwords has
its advantages. I was laid off a year and a half ago. The owners of the
company hired a consultant to change the system passwords, and I made a list
to make sure they got them all. I ended up giving them about 4 hours of free
consulting when everything broke (due to services not having the right
passwords, automatic file transfers getting access denied, etc), but I
wanted (and got) a letter of recommendation. During that time, I made sure
someone was with me at all times that I was in the building and that I did
not see any new passwords being entered. I had a policy (and it was well
known) that I did not know anyone else's passwords. If anything happened
after the change-over, I could point out that I did not have the access to
do it.
Sent: Thursday, August 01, 2002 7:08 PM
Subject: Re: [Vantage] Re: Another Enhancement Request for all you progres s
At 10:17 PM 8/1/2002 +0000, you wrote:
>If we only had the decryption algorithm for UserFile.password...
I've heard there is an "encrypt" function in the Progress 4GL. Maybe
that's what they used? If so, just do the standard password check routine
of encrypting the password entered by the user and comparing it to the
stored one.
If that works, it would also let you easily run the "password audit"
mentioned, too.
-Wayne Cox
Twenty Three - Information Technology Consulting
828-685-2338
What I was going for (and has been added to the epicor ER list) is a command
that can be called from a progress program running outside of Vantage. It
would authenticate the user before generating data for them.
If I am running a program from a VB form, something like getVantageID()
works.
This was intended for allowing users access to timesheets without having to
log into Vantage but still making sure that only Joe can access Joe's
timesheet. When each user has their own NT login, I use the NT username (and
some string editing) to get their EmpBasic record and then the EmpID field.
This works pretty well, but some user's share a PC and use a generic login.
For those, this ER would be handy.
Sent: Thursday, August 01, 2002 12:43 PM
Subject: [Vantage] Re: Another Enhancement Request for all you progress
Hi Greg,
Not sure if this is what you're looking for, but there is a variable
DCD-UserID which will yield the current Vantage user.
def shared variable DCD-UserID as char no-undo.
message dcd-userid view-as alert-box.
Save the above as UDsomething.w, add to Vantage menu and give it a
try.
Lonnie
--- In vantage@y..., Greg Krumrey <gkrumrey@p...> wrote:
> Here's another one for you.
> Company: Patriot Machine Inc.
> Contact: Greg Krumrey
> Call Placed by: greg.krumrey@p...
> Product: Vantage
> Module: Miscellaneous
> Version: 5.10.124
> Option: N/A
> Description: User Authentication from Progress Routine
> Detail: On more then one occasion, I've wanted to make sure a user
really is
> who they say they are. In some cases, I can use their NT username,
but in
> most, they are logged into NT in a generic username. A progress
function
> (similar to getStringValue) that would prompt for the System Login
(which
> comes up when Vantage) is started, and report back Succeed or Fail
and a
> Vantage UserID would fill this need.
> email: mailto:greg.krumrey@p...
> Alt: mailto:greg@k... Web: www.patriot-machine.com
How about gathering and storing shop personnel passwords in a text
file, encrypted if you wish. Verify ID and PW against your PW text
file.
I've created a user table for other programs, but accessing Vantage's
would've made it much easier.
Good luck
a command
Vantage. It
getVantageID()
> works.
having to
Joe's
username (and
EmpID field.
generic login.
> Thanks,
> From: lonniedrew [mailto:lonniedrew@c...]
> To: vantage@y...
progress
> Hi Greg,
variable
> try.
> Lonnie
> > Product: Vantage
> > Version: 5.10.124
> > Option: N/A
user
> really is
username,
> but in
> function
Login
> (which
Fail
> and a
must have
Builder and
How about an Administrator's Password Export utility, which only a security
manager can invoke. The utility would export user names and passwords of
vantage users. (Or an external .p that could be run from a .vtg file), and
secured with NT permissions.
This way, security managers can make sure that their users password isn't
something obvious, like their last name, birth day, or the ever so common
'password'.
The password export could also be used to assist in-house developers with
developing solutions that authenticate based on a Vantage UserName and
Password, but the main benefit I would see is increased security that comes
with password auditing.
Thaddeus Jacobs
Information Solutions Developer
Kinematic Automation, Inc.
mailto:tjacobs@...
Sent: Thursday, August 01, 2002 3:17 PM
Subject: [Vantage] Re: Another Enhancement Request for all you progres s
file.
Good luck
a command
Vantage. It
getVantageID()
> works.
having to
Joe's
username (and
EmpID field.
generic login.
> Thanks,
> To: vantage@y...
progress
> Hi Greg,
variable
> try.
> Lonnie
> > Product: Vantage
> > Version: 5.10.124
> > Option: N/A
user
> really is
username,
> but in
> function
Login
> (which
Fail
> and a
must have
Builder and
stored one.
mentioned, too.
-Wayne Cox
828-685-2338
same).
Salt).
do it.
stored one.
mentioned, too.
-Wayne Cox
828-685-2338
So Epicor claims they have their own "Encode" function. Interesting, a
couple years ago I created and ran a decode program using the Progress
"Encode" function as the comparison function, it was able to extract all my
Vantage User Passwords from Vantage. So with the results from this
experiment, I would have to say that Epicor did in fact use the Progress
"Encode" function for the user password verification. Is this useful
information? Not really, as a Vantage administration you can log into
Vantage and change any user's password, expire it, etc. The only reason one
would need access to this information, was if someone hacked the system and
changed all user passwords so that you and everyone else couldn't log in at
all. But then again, it would be much quicker to open that table in
Provision and just edit the password field with a known password, log in as
the manager and fix all the users passwords.
progres s programmers out there...
same).
Salt).
do it.
stored one.
mentioned, too.
-Wayne Cox
828-685-2338
