Perfect Rob, thanks..That makes sense. I will make the change. I did end
up getting it to work. I just had to "populate" the combobox on the tracker
screen with the items as I guess it "has" to match something in a list in
order to display. But I like your idea much better. Thanks again, my
friend!
Mike..
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf Of
Rob Bucek
Sent: Friday, September 21, 2012 2:03 PM
To:
Subject: RE: [Vantage] RE: Another Newbie question on customization
In the tracker I would advise to just use a text box to display information.
Since you can't update from a tracker there isn't much point to using the
combo. That being said, assuming in Job Entry you tied the ultracombo to the
JobHead.Character01 (and some advice here, unless this is some sort of memo
or string exceeding 50 characters, I strongly advise using the ShortChar
fields before character fields), and in Job Tracker you tied the text box to
the same table/column it should display.
Rob Bucek
Production Control Manager
PH: (715) 284-5376 ext 311
Mobile: (715)896-4832
FAX: (715)284-4084
[Description: cid:
1.234354861@...
<mailto:1.234354861%40web65412.mail.ac4.yahoo.com> ]<
http://www.dsmfg.com/>
(Click the logo to view our site)<
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
[mailto:
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
Behalf Of Mike Abell
Sent: Friday, September 21, 2012 11:55 AM
To:
Rob,
You are THE man. That worked perfect..I've only got one last thing now. I
went and added the same field to the JobTracker screen so I could see this
new field when either entering OR just looking at a job. However, even
though I bound the new ultra combo control to the same field I did in the
Job Entry screen, it does not retrieve the data that I entered when I did
with Job Entry. It pulls up fine in Job Entry, but JobTracker it does not.
Any ideas? Could it be because I did not "populate" the ultracombo in the
JobTracker with a list of items but I did populate it in Job Entry? That's
really the only difference I can think of. Thanks!
Mike.
<mailto:vantage%40yahoogroups.com> [mailto:
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>] On
Behalf Of
Rob Bucek
Sent: Friday, September 21, 2012 11:21 AM
To:
Under system, go to utilities, menu maintenance, look for the menu item,
youll see a drop down selection for customization. Choose that, log out of
Epicor and back in.
Rob Bucek
FAX: (715)284-4084
[Description: cid:
1.234354861@...
[mailto:
<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Sent: Friday, September 21, 2012 11:17 AM
To:
Thanks Rob,
I think I've got it all working now (I added the field and bound it to data)
but how exactly do I "enable" this new UltraCombo control I added to be seen
when I exit out of developer mode? I can see it and it works as long as I
am "developer/customizing" but as soon as I go back out, everything reverts
back to the way it was before I started. I did not save it as a "WIP" (work
in process) customization. What am I missing to actually get it to work in
a "running" environment??? Thanks!
Mike..
Behalf Of
Rob Bucek
Sent: Friday, September 21, 2012 9:16 AM
To:
Subject: [Vantage] RE: Another Newbie question on customization
Sorry, my bad... I was referring to the second part of your question about
the mandatory portion, the other reply should steer you in the direction to
add a combobox..
Specifically, when you have the customization screen open under tools menu
pick tool box and add ultracombo
Rob Bucek
FAX: (715)284-4084
[Description: cid:
1.234354861@...
[mailto:
Sent: Friday, September 21, 2012 8:42 AM
To:
Thanks Rob....Care to point me in the right direction? The only "wizards" I
see are when I'm in the developer/customization mode. And none of those
"wizards" appear to take me through the process of adding a new field to a
form. Am I missing something???
Mike Abell
Systems Analyst / Network Administrator
Flexial - BOA Group - Cookeville, Tennessee
Office: 931.432.1853 ext 302
Mobile: 615.418.3055
email:
MAbell@... <mailto:MAbell%40flexial.com>
<mailto:MAbell%40flexial.com> <mailto:MAbell%40flexial.com>
Behalf Of Rob Bucek
Sent: Friday, September 21, 2012 8:10 AM
To:
You should be able to do this with a pre-processing BPM using some of the
standard 'wizard' choices...
Rob Bucek
FAX: (715)284-4084
[Description: cid:
1.234354861@...
<mailto:1.234354861%40web65412.mail.ac4.yahoo.com><mailto:1.234354861%40web6
<mailto:1.234354861%40web6%0b%3cmailto:1.234354861%40web6%0b5412.mail.ac4.ya
hoo.com>
<mailto:1.234354861%40web6%0b5412.mail.ac4.yahoo.com>
5412.mail.ac4.yahoo.com>]<
<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
[mailto:
<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On
Sent: Thursday, September 20, 2012 5:19 PM
To:
Subject: [Vantage] Another Newbie question on customization
Vantage gurus,
I have another "newbie" question. I need to add a combobox control to the
"Job Entry" screen in our Vantage 8.03 and call it "Job Type" and populate
it with a list of selectable items and data bind that selection to the
JobHead.Character1 field in the database when the job is created. I also
wanto to make it a "mandatory" field that has to have something selected in
it before a new job can be created. Can this be done without any coding?
Thanks in advance..
Mike Abell
email:
<mailto:MAbell%40flexial.com><mailto:MAbell%40flexial.com><mailto:MAbell%40f
<mailto:MAbell%40f%0b%3cmailto:MAbell%40f%0blexial.com>
<mailto:MAbell%40f%0blexial.com>
lexial.com>
