Any help with installing Altec
It has been my experience, installing APM 2.5 with a 'fresh' database,
that the database is completely empty and does not contain the default
admin user so it is impossible to login. I would contact support.
I had an older version database so I was able to run conversion scripts
on it.
bw
--- In vantage@yahoogroups.com, "kirsty2179" <dobby01@...> wrote:
> Can anyone tell me where i can change login detail to administrator
> (Altec)
> becauses since upgrade i,m lock out?
Due to server movement and problems with upgrade to 803.403d, Need to
re-stall ALTEC,
So i get software download SQL express and put cd into install Altec
and that it and then get told that i do not have sql install oh but i do
Any Help ?
You will have to enter the correct name of your SQL installation. It
will be something like "SQL Express" and not the default. I can't
remember exactly what it should be. I had other issues with ALTEC
installation and was never able to get it to use SQL Express. I was
relegated to using SQL 2000 developer.
Of kirsty2179
Sent: Tuesday, May 13, 2008 2:17 AM
Subject: [Vantage] Any help with installing Altec
re-stall ALTEC,
Any Help ?
Charles Carden
Manager, MIS
Manitex, Inc.
Phone: 512-942-3086
Fax: 512-942-3089
DISCLAIMER:
This e-mail, including attachments, may include confidential and/or
proprietary information, and may be used only by the person or entity to
which it is addressed. If the reader of this e-mail is not the intended
recipient or his or her authorized agent, the reader is hereby notified
that any dissemination, distribution or copying of this e-mail is
prohibited. If you have received this e-mail in error, please notify the
sender by replying to this message and delete this e-mail immediately.
Kristy,
If it is anything like a Service Connect install to SQLExpress, add
"\SQLExpress" to the end of the server name when prompted (i.e.
"Servername\SQLExpress" and you should be good to go.
William Hannah
Director of Finance
William Frick & Company
Phone: 847-918-7338
William.Hannah@... <mailto:William.Hhannah@...>
Of kirsty2179
re-stall ALTEC,
Any Help ?
Thanks will try the SQL 2000 Developer as every time I try to create
database i get told there interfere,s.
Why don,t think make things straight forward or even give you correct
instruction,s
> Of kirsty2179
> re-stall ALTEC,
> Any Help ?
> Charles Carden
> Manager, MIS
> Manitex, Inc.
> Phone: 512-942-3086
> Fax: 512-942-3089
> DISCLAIMER:
(Altec)
