Does anyone know of a way to see if an Epicor session was spawned from the client or the browser? I was hoping that the ‘GetUserSessionAndVersion’ method call that is called during login would contain this information but I have been unable to find it.
My goal is to trigger a BPM on user login that behaves differently depending on if the user used the client or the web browser. I know the kinetic client at this points is basically a web browser in its own right but I was hoping there was some flag somewhere with the distinction. Thanks, any insight is appreciated.
Thanks for this. This seems to be the closest. I was hoping to check during the SessonMod.Login call but it seems that CallContextClientData.ClientType is blank during this as the session hasn’t been spawned yet. I’ll have to think of a future downstream trigger I think.
If you are interested if the user is running in the Kinetic browser in the Smart Client vs Kinetic in your default browser, you can also look at the user agent.
Most of the time, the version of the Smart Client browser will be far behind the latest version of Chrome or Edge.
May not be 100% reliable between upgrades as you will have to update the version number if Epicor decides to update the Smart Client Browser version.
if (callContextClient.ClientType == "WinClient")
// Classic running in Smart Client
return;
// Get user agent
string userAgent;
if (Operation.Current.HttpHeaders.TryGetValue("User-Agent", out userAgent) == false)
// No User agent
return;
var match = Regex.Match(userAgent, @"Chrome\/(?<version>\d+)");
if (match.Success == false)
// No match
return;
var chromeVersion = Convert.ToInt32(match.Groups["version"].Value);
// If greater than this version (120 as of 2024.2), the default browser is being used
if (chromeVersion > 120)
// Kinetic in Default browser
else
// Kinetic in Smart Client
