Argh.. can't win. It loses the maximized setting after you close the
window you looked from. i.e. Open Job Entry, do a search and
maximize and save it - it works and keeps it maximized for each
search.
However, close the Job Entry screen - reopen it and try to do a new
search and now it no longer opens maximized for the search.
search.
--- In vantage@yahoogroups.com, "Patrick Parker" <pbparker@...> wrote:
> Heh, you're right, I've confirmed that happens here on 8.03.404 too.
> Now.. if we could only get something functioning in between the
small
> size and the maximized window. However, having the maximized
window
> option at this point is better than nothing.
> I'll pass that method along to our users to see if that works for
> them.
> --- In vantage@yahoogroups.com, "Calvin Krusen" <ckrusen@> wrote:
> > Here's and odd situation...
> > If you maximize a search window, the right click in the area
where
> > the serach results grid will appear (or to the right of the grid
if
> > one is already there) and select 'Save layouts', then next time
the
> > search window is loaded, it will start maximized.
> > This only seems to work if the window is truely maximized (not
just
> > manually stretched to the screen extents).
> > P.S. The above is for Version 8.03.403D
> > Calvin Krusen
> > Operations Engineer
> > MATCOR Inc
> > --- In vantage@yahoogroups.com, "Manasa Reddy" <manasa@> wrote:
> > > I take it back, you were talking about the whole screen
> > itself....for
> > > some reason I was thinking about the column width...
> > > Sorry....
> > > M. Manasa Reddy
> > > manasa@
> > > P: 630-806-2000
> > > F: 630-806-2001
> > > ________________________________
> > > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]
On
> > Behalf
> > > Of Manasa Reddy
> > > Sent: Wednesday, March 26, 2008 3:09 PM
> > > To: vantage@yahoogroups.com
> > > Subject: RE: [Vantage] Re: Any way to save search results
screen
> > size?
> > > What version are you guys on? Because it works on
mine....8.0.812
> > > M. Manasa Reddy
> > > manasa@ <mailto:manasa%40weldcoa.com>
> > > P: 630-806-2000
> > > F: 630-806-2001
> > > From: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > > [mailto:vantage@yahoogroups.com <mailto:vantage%
> > 40yahoogroups.com> ] On
> > > Behalf
> > > Of Michael McWilliams
> > > Sent: Wednesday, March 26, 2008 2:32 PM
> > > To: vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> > > Subject: [Vantage] Re: Any way to save search results screen
size?
> > > Your right, I never tried that. It keeps the order of the
columns
> > > if you change but not the size.
> > > --- In vantage@yahoogroups.com <mailto:vantage%
40yahoogroups.com>
> > > <mailto:vantage%40yahoogroups.com> ,
> > > "Patrick Parker" <pbparker@>
> > > wrote:
> > > > That doesn't work on the search results. It works on every
> other
> > > > screen.
> 40yahoogroups.com>
> > > "Michael McWilliams"
> > > > <mmcwilliams22@> wrote:
> > > > > You should be able to right click & choose save layouts.
> > 40yahoogroups.com>
> > > wrote:
> > > > > > We (I'm sure everyone does) have various searches where
the
> > > > results
> > > > > > have many columns that we need to see, so you resize the
> > > window
> > > > > wider
> > > > > > to see the multiple columns.
> > > > > > Only problem is I see is no way of saving that width so
the
> > > next
> > > > > time
> > > > > > you search - it retains that width. It always seems to
snap
> > > back
> > > > to
> > > > > > the smallest original size.
> > > > > > There any way to save that search result size?
