Anyone else having problems with related OPS on parts under phan
Instead of removing the operations, we change them to backflush. We do this so that we can put a comment on the operation that tells them that it's a backflush op so they don't try to clock into it, and more importantly what subassembly they are making in case they need to reference a print. We need them to be able to get the information that they need without having to do all of the extraneous reporting. These operations that are pulled up as backflush, then automatically get completed when the level up time/qty reporting operation gets completed. It works well. Also since the parts from the phantom BOM are still related to that op that got pulled up, you can look through your tree in the job and see what resources are required for each operation, thus semi preserving the tree so you can relate your prints to what you have on the job.
That all works really well. The issue we are having is the assemblies under the phantom boms. For example a weldment that is part of a phantom bom, but not a phantom bom itself. The parts that go into that weldment (usually laser brake, or some combination of fab activities) are the ones that aren't related correctly to the welding operation. The odd thing is, it's only the assemblies, not the materials that are having this issue.
So I've been going back and forth with service for a while trying to get them to be able to recreate a problem we are having with assemblies being related to their proper operations after their parents have been pushed up a level. The agent that I am working with hasn't been able to recreate the problem. I've tried in base mode, and even with the training database to show that it isn't our system, and I can recreate the problem every time. Below is a text example of a tree that would cause the problem. Hopefully the word wrap doesn't clutter up what I am trying to show to badly.
Does anyone else see this behavior in your system? We are on E10.0.700.4
Brandon
Method tracker
Asm 1 top level (op 10 for asm 2)
                Asm 2 phantom bom (op 10 for asm 2)
                                Asm 3 regular bom (related to op 10 for asm 2)
                                                Asm 4 (related to op 10 for asm 3)
                                                Asm 5 (related to op 10 for asm 3)
                                                Asm 6 (related to op 10 for asm 3)
                Asm 7 phantom bom
                                Asm 8 not phantom bom (related to op 10 for asm 7)
                                                Asm 9 (related to op 10 for asm 8)
                                                Asm 10 (related to op 10 for asm 8)
                                                Asm 11 (related to op 10 for asm 8)
After get details on the job
Asm 1 (related to op 10 for asm 1)
Asm 3  (related to op 20 from asm 2)
                Asm 4 – Here is where the problem is, this should be related to op 10 for asm 3,
                                however it will show up as related to op 20, which doesn’t exist
                Asm 5- Here is where the problem is, this should be related to op 10 for asm 3,
                Asm6 - Here is where the problem is, this should be related to op 10 for asm 3,
Asm 8 (related to op 30 from asm 7)
                Asm 9 - Here is where the problem is, this should be related to op 10 for asm 3,
                            however it will show up as related to op 30, which doesn’t exist
                Asm 10 - Here is where the problem is, this should be related to op 10 for asm 3,
                Asm 11 - Here is where the problem is, this should be related to op 10 for asm 3,
Operations
Op 10  for asm 1
Op 20 (was op 10) from asm 2
Op 30 (was op 10 ) from asm 7
Hi Brandon,
Are using Alt Methods?
Don Kollmann
ACH Foam Technologies
Sent: Monday, August 1, 2016 1:28 PM
Subject: [Vantage] anyone else having problems with related OPS on parts under phantom BOM's?
Brandon
Method tracker
                Asm 7 phantom bom
Operations
Op 10  for asm 1
I am not. Not on purpose anyways.
We have multi-site and for every method we have built for the part it compounded the operation in the display when trying to relate the materials to an operation.
Don Kollmann
Sent: Monday, August 1, 2016 2:48 PM
Subject: RE: [Vantage] anyone else having problems with related OPS on parts under phantom BOM's?
We just have one method for each part. So that's not our problem. Did you end up fixing your issue? Or do you have a work around?
I don’t have a fix sorry we are still in testing phase of Epicor 10
Don Kollmann
Sent: Monday, August 1, 2016 4:38 PM
Subject: [Vantage] Re: anyone else having problems with related OPS on parts under phantom BOM's?
In our version 9.05.700b if you have operations on a phantom it will pull those operations and material to its parent.  Hence if the part is meant to be a phantom and not a subassembly we want to be told to make we need to remove the operations.
