Anyone know how to add an exclusion field to an added table in 1
Mr. Stephen: This is SaaS Multitennant environment.
We are testing in the 10.1 Sandbox Pilot - not sure of the exact version.
DaveO
Epicor 10.1 SaaS
I added a ECOREV table to my standard OrderAck RDD.
I am not getting my UD fields to output to the XML.  ECOREV.Number05 - 07.
So I went into the RDD and tried to Explicitly add the fields to the ECOREV table  as exclusions and then un-exclude them ( a trick I learned in 10.0).
However, I am unable to find out how to add a field to the exclusion list in V10.1.
I see from the Action menu the "Include ALL Columns" but that does not seem to do anything.
Anyone have any ideas?
Dave Olender (DaveO)
Ph: 651-246-3281
The more important question is,.... YOU HAVE 10.1? (Is it the savior we all expect?)
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Fri, Oct 23, 2015 at 2:37 PM, daveolender@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p></p><p><span>Epicor 10.1 SaaS</span></p><p><span>I added a ECOREV table to my standard OrderAck RDD.</span></p><p><span>I am not getting my UD fields to output to the XML.  ECOREV.Number05 - 07.</span></p><p><span><br></span></p><p><span>So I went into the RDD and tried to Explicitly add the fields to the ECOREV table  as exclusions and then un-exclude them ( a trick I learned in 10.0).</span></p><p><span><br></span></p><p><span>However, I am unable to find out how to add a field to the exclusion list in V10.1.  </span></p><p><span><br></span></p><p><span>I see from the Action menu the &quot;Include ALL Columns&quot; but that does not seem to do anything.</span></p><p><span><br></span></p><p><span>Anyone have any ideas?</span></p><p><span><br></span></p><p><span>Thanks,</span></p><p><span><br></span></p><p><span>Dave Olender (DaveO)</span></p><p><span>Ph: <a rel="nofollow">651-246-3281</a></span></p><p></p>
</div>
<div style="color:#fff;min-height:0;"></div>
I must admit I'm only using a small part of it as part of support for a SaaS customer.
I like some of the new features I have seen for SaaS customers i.e. we can download our own XML and RPT files - as well as the SSRS RPT files.
The other 289pages of new stuff - must admit I have only done a cursory review and cannot vouch for.
Sorry I wish I had a better answer,
I'm like you - I have high hopes,
Take Care,
DaveO
#ygrps-yiv-1682678572 P.ygrps-yiv-1682678572b1e7fd89-0279-4ffe-a16a-1f1bcba0d537 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1682678572 LI.ygrps-yiv-1682678572b1e7fd89-0279-4ffe-a16a-1f1bcba0d537 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1682678572 DIV.ygrps-yiv-1682678572b1e7fd89-0279-4ffe-a16a-1f1bcba0d537 { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1682678572 TABLE.ygrps-yiv-1682678572b1e7fd89-0279-4ffe-a16a-1f1bcba0d537Table { MARGIN:0cm 0cm 0pt;} #ygrps-yiv-1682678572 DIV.ygrps-yiv-1682678572Section1 { }
Dave
Are you testing this in SaaS or on premise ? And if in SaaS is this single tenancy or multi tenancy?
Also confirm the exact version are you talking 300.1?
On 23 Oct 2015, at 20:31, daveolender@... [vantage] <vantage@yahoogroups.com> wrote:
Take Care,
DaveO
Stephen Edginton (Beng) | Solutions & Technical Director
Mobile:  +44 7734 858415
DDI:  +44 121 314 1179
Main:  +44 (0) 121 314 1170
Web:  www.dotnetit.co.uk
Dot Net IT Limited, One St Kenelm Court, Steel Park Road, Halesowen, B62 8HD, United Kingdom.
DotNetIT
Epicor Platinum Partner
Epicor Alliance Partner
