Anyone out there? Please help - OCX errors on TerminalServer/C
We had a similar situation where one of the files (from memory, I think it
was ctfold.ocx) was getting locked. If all users logged out of the terminal
server, the file would unlock.
I just went through this problem with Vantage tech support. Besides
recommending that the directory containing the OCXs on the terminal server
be set to read only, they also sent me a batch file. Basically, it looks
like it goes through and reregisers all the OCXs to point to where they are
located on the server instead of the local machine.
So if problems persist, call Vantage support and ask if they can send you
the same batch file.
Brian
I'm hoping someone is out there this morning... I went forward with the
upgrade from 5.0 to 5.2 last night. I had already tested it a few weeks
back and it went smoothly last night, UNTIL it came to installing on Citrix.
I followed the directions, but I cannot get past all kinds of strange
ActiveX and Ocx errors. Users can log in, but cannot access key modules of
the system and it is unuseable to all my off-site users (10 office, 50 Data
Collection). I have installed almost all local boxes and I am not having
any problems on those. I have tried searching the archives both on yahoo
groups and epicor eportal and have tried everything I've come across, but no
luck. I am @ ie 6.002. I tried running the regsrv32, forcereg, unregocx, no
luck. When I tried the Instocx.exe, it will run fine on any other
workstation, but when I try it from terminal server, I get an error that
Msvbvm50.dll can not be opened and it does not run. I'm just wishful
thinking that someone is out there and knows what the heck I'm talking
about, b/c I've been here for way too long at this point and I have no idea
what to do, other than wait to call vantage tech support Monday morning...
I am also getting an ocx error as I am upgrading from 5.1 to 5.2.
Mine is with syslogin.w, and so far is only happening on the server.
Sounds like you have tried so far what I am going to try. If I have
any luck I'll passs it along. I am at 262-567-7256 x131. Good
luck. I am at IE version 5.00.3315.1000 and was considering going to
6.0 version...but from your situation sounds like that will not
help.
Lance Ekum
Sentry Equipment
with the
weeks
on Citrix.
strange
modules of
50 Data
having
yahoo
across, but no
unregocx, no
that
wishful
talking
no idea
morning...
Check the msvbvm.dll file to see if it is marked as read only. Check
both security plus on the general screen under properties for the
file there is a read only box. Make sure it is not set to read only
in either of these places.
Lance
262-567-7256 x131
with the
weeks
on Citrix.
strange
modules of
50 Data
having
yahoo
across, but no
unregocx, no
that
wishful
talking
no idea
morning...
