Anyone using PartPlant: Reschedule-in-Delta and Out-delta to stop M
Good Day:
RE: Anyone using PartPlant:  Reschedule-in-Delta and Out-delta to stop MRP rescheduling JOB’s ;  that is: use =720???
            I want to stop MRP from trying to reschedule JOB’s; that is, stop it from issuing pull-in-pull-out-suggestions for JOBs
            If I put 900 in both Reschedule-in-Delta and Reschedule-out Delta, will MRP stop trying to reschedule them, even if it is being below safety stock that caused the need to Make some.
        Len
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
