Ap check print problem
We are on versions 5.10.124. Vantage used to let you know when you reached
your allowed number of items per check. We have had problems (which I was
just made aware after forwarding the related problem to AP) where the
warning no longer comes up. Amounts will print to a second check...wasting
the check and throwing the whole batch out of line.
We recently have upgraded from 5.10.110.
Sent: Tuesday, June 11, 2002 2:17 PM
Subject: RE: [Vantage] AP CHECK PRINT PROBLEM
Check and make sure that the printer drivers for the printer
are the SAME on
the upgraded PC as they were on the Win98 PC.
I have seen this before and it may be the cause of the
problem. You can
check at Epicor to see if there is a fix for this issue if
it is not a PC
issue.
Kevin Kadamus
Consulting Services
kadamus@...
802-626-9219 (office)
802-274-0224 (cell)
Sent: Tuesday, June 11, 2002 1:31 PM
It was not a new printer and no changes were made to the
printed check
report file (or so I have been told). The A/P clerk did
get a new CPU and
was upgraded from Win98 to Win2000.
Mary Horsey
HR Manager
Greene Rubber Company
20 Cross Street
Woburn, MA 01801
781-497-1851
mhorsey@...
Sent: Tuesday, June 11, 2002 12:35 PM
Is this a new printer? Has anything changed since the
last time you
printed, such as a change to the printed check report
file?
Sometimes a new or different printer is used and the
drivers are not
compatible. Look into what may have changed since the
last time you
printed.
Kevin Kadamus
Consulting Services
kadamus@...
802-274-0224 (cell)
Sent: Tuesday, June 11, 2002 9:56 AM
Subject: [Vantage] AP CHECK PRINT PROBLEM
We just printed a batch of checks last week and this
problem showed up.
On
two checks when the # of remittance items ran over to
another check, it
printed 3 checks! The third check was a duplicate of
the whole amount
we
were paying. The other two were right - the amount that
was remitted on
each check. Has anyone ever run into this before?
Useful links for the Yahoo!Groups Vantage Board are: (
Note: You must
have already linked your email address to a yahoo id to
enable access. )
(1) To access the Files Section of our Yahoo!Group for
Report Builder
and
(3) To view links to Vendors that provide Vantage
services goto:
Your use of Yahoo! Groups is subject to the Yahoo! Terms
of Service.
Note: You must
have
already linked your email address to a yahoo id to enable
access. )
Report Builder and
(3) To view links to Vendors that provide Vantage services
goto:
of Service.
Yahoo! Groups Sponsor
ADVERTISEMENT
Note: You must
enable access. )
Report Builder and
goto:
of Service.
------------------------ Yahoo! Groups Sponsor
Useful links for the Yahoo!Groups Vantage Board are: ( Note:
You must have already linked your email address to a yahoo id to enable
access. )
Report Builder and Crystal Reports and other 'goodies', please goto:
goto: http://groups.yahoo.com/group/vantage/links
http://docs.yahoo.com/info/terms/
We just printed a batch of checks last week and this problem showed up. On
two checks when the # of remittance items ran over to another check, it
printed 3 checks! The third check was a duplicate of the whole amount we
were paying. The other two were right - the amount that was remitted on
What version and patch are you on?
Sent: Tuesday, June 11, 2002 8:56 AM
showed up. On
another check, it
whole amount we
remitted on
access. )
We are on version 5.10.114 and progress 9.1C Full. Does that answer your
question or do I need more? Sorry we don't have an MIS Manager so I have to
try to find answers to help a consultant we have at the present time.
Mary Horsey
HR Manager
20 Cross Street
Woburn, MA 01801
781-497-1851
mhorsey@...
Sent: Tuesday, June 11, 2002 10:21 AM
showed up. On
another check, it
whole amount we
remitted on
access. )
Is this a new printer? Has anything changed since the last time you
printed, such as a change to the printed check report file?
Sometimes a new or different printer is used and the drivers are not
compatible. Look into what may have changed since the last time you
printed.
Kevin Kadamus
Consulting Services
kadamus@...
802-274-0224 (cell)
On
It was not a new printer and no changes were made to the printed check
report file (or so I have been told). The A/P clerk did get a new CPU and
Mary Horsey
HR Manager
20 Cross Street
Woburn, MA 01801
781-497-1851
mhorsey@...
printed.
Kevin Kadamus
Consulting Services
kadamus@...
802-274-0224 (cell)
On
Check and make sure that the printer drivers for the printer are the SAME on
I have seen this before and it may be the cause of the problem. You can
check at Epicor to see if there is a fix for this issue if it is not a PC
issue.
Kevin Kadamus
Consulting Services
kadamus@...
802-274-0224 (cell)
Mary Horsey
HR Manager
20 Cross Street
Woburn, MA 01801
781-497-1851
mhorsey@...
printed.
Kevin Kadamus
Consulting Services
kadamus@...
802-274-0224 (cell)
On
we
and
have
ADVERTISEMENT
