In Vantage 5.2 the AP discount is not calculated against a miscellaneous
charge. Epicor support says that this has now been fixed in 6.0, but did
not state which release. Their fix is to create a manual override
calculation.
In most companies, the person entering the Invoice is not always the one who
determines whether a check will be cut in time to take the discount. Epicor
is adding a manual, time consuming (it adds up) step to a process that
should be automated. Not automated also means risk of error.
In the mean time Epicor's customer's are loosing money because the discount
is not being calculated correctly.
If you also have this as a concern...please contact Epicor.
Thank you,
Carol Engen
Controller
Winona Lighting
Phone: 507-454-5113, Ext. 314
Fax: 507-454-4806
e-mail: cengen@... <mailto:cengen@...>
calculation.
Thank you,
Carol Engen
Controller
Winona Lighting
Fax: 507-454-4806
