API Error
Hi all,
Has anyone come across this error before?
Event code: 3005
Event message: An unhandled exception has occurred.
Event time: 09/05/2022 13:53:50
Event time (UTC): 09/05/2022 12:53:50
Event ID: 24b250a5234f456ba28012353e79a55f
Event sequence: 4
Event occurrence: 1
Event detail code: 0
Application information:
    Application domain: /LM/W3SVC/1/ROOT/ERP10-1-132965744080861197
    Trust level: Full
    Application Virtual Path: /ERP10
    Application Path: C:\inetpub\wwwroot\ERP10\Server\
    Machine name: EPICOR
Process information:
    Process ID: 12576
    Process name: w3wp.exe
    Account name: TEAGLE0\EpicorSVC
Exception information:
    Exception type: OperationCanceledException
    Exception message: The operation was canceled.
   at System.Threading.CancellationToken.ThrowOperationCanceledException()
   at System.Web.Http.Owin.HttpMessageHandlerAdapter.<SendResponseContentAsync>d__33.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
   at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   at System.Web.Http.Owin.HttpMessageHandlerAdapter.<InvokeCore>d__20.MoveNext()
   at Epicor.RESTApi.Middleware.ApiKeyEnforcerMiddleware.<Invoke>d__3.MoveNext() in C:\_Releases\ICE\ICE3.2.400.38\Source\Framework\Epicor.RESTApi\Epicor.RESTApi\Middleware\ApiKeyEnforcerMiddleware.cs:line 44
   at Microsoft.Owin.Cors.CorsMiddleware.<Invoke>d__4.MoveNext()
   at Microsoft.Owin.Mapping.MapWhenMiddleware.<Invoke>d__3.MoveNext()
   at Microsoft.Owin.Host.SystemWeb.IntegratedPipeline.IntegratedPipelineContextStage.<RunApp>d__7.MoveNext()
   at Microsoft.Owin.Host.SystemWeb.IntegratedPipeline.IntegratedPipelineContext.<DoFinalWork>d__12.MoveNext()
   at Microsoft.Owin.Host.SystemWeb.IntegratedPipeline.StageAsyncResult.End(IAsyncResult ar)
   at System.Web.HttpApplication.AsyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
   at System.Web.HttpApplication.ExecuteStepImpl(IExecutionStep step)
   at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
Request information:
    Request URL: https://epicor:443/erp10/api/help/v1/
    Request path: /erp10/api/help/v1/
    User host address: 192.168.22.22
    User: AaronG
    Is authenticated: True
    Authentication Type: Ice
    Thread account name: TEAGLE0\EpicorSVC
Thread information:
    Thread ID: 21
    Is impersonating: False
    Stack trace:    at System.Threading.CancellationToken.ThrowOperationCanceledException()
Custom event details:
We also keep getting these
A fatal alert was received from the remote endpoint. The TLS protocol defined fatal alert code is 46.
It’s just started happening.
Need a bit more context guys…
Apologies, we use the API through our web portal which uses PHP to submit through the API. It was working perfectly then all of a sudden the website know throws an error.
When I visit the swagger help page for the API I get this error message on the ERP Server event logs. I have googled the hell out of it and no avail. I recently found the error on the original post but I can’t make out what is causing the issue.
Is the correct certificate selected in IIS for your site?
And is your TLS level correct? (At least 1.2 or higher)
How do I check this?
For publicly facing sites, you can use a TLS checker like this one:
TLS Checker - Instant Results | CDN77.com
For your Epicor server, you would check registry settings as well as WebConfig settings (there’s a post out here about that)
Transport Layer Security (TLS) registry settings | Microsoft Docs
