APM 2.7 - SOA/PackSlip Multiple Lines Setup
How is it decided what is grouped under the LineRef ? I notice it does it for part number, but not the revision.
I haven't found a place in the doc-link Administrator to define what should be grouped or not.
--- In vantage@yahoogroups.com, Jose Gomez <jose@...> wrote:
> Yeah that should work. That's basically what we do, we have the field which
> covers the "WHOLE" Part section of the form and we don't actually have any
> script for it because our parts are always within the range.
> *Jose C Gomez*
> *Software Engineer*
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez> <http://www.facebook.com/josegomez>
> <http://www.google.com/profiles/jose.gomez> <http://www.twitter.com/joc85>
> <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
> <http://www.usdoingstuff.com>
> *Quis custodiet ipsos custodes?*
> On Tue, Apr 9, 2013 at 6:29 PM, justincalbraze <
> justint@...> wrote:
> > How are you guys handling the multiple lines with regards to Part Numbers?
> > Do you just set it up so everything is moved away from the field and
> > detection covers the entire form and add a script like:
> > If instr(PropertyValue, "Part: ") <> 0 Then
> > TextOut =
> > Trim(right(PropertyValue,(len(PropertyValue))-(inStrRev(PropertyValue,":")
> > End If
> > The original part number field had a script of:
> > If isnumeric((left(PropertyValue,1))) then
> > if (left(PropertyValue,1) > 0) then
> > if instr(right(PropertyValue,3), ".") = 0 then
> > TextOut =
> > trim(right(PropertyValue,(len(PropertyValue))-(inStrRev(PropertyValue," ")
> > End If
> > Which I didn't fully understand... They only planned for someone to use a
> > numeric part number?
Do you just set it up so everything is moved away from the field and detection covers the entire form and add a script like:
TextOut = Trim(right(PropertyValue,(len(PropertyValue))-(inStrRev(PropertyValue,":") ) ) )
End If
TextOut = trim(right(PropertyValue,(len(PropertyValue))-(inStrRev(PropertyValue," ") ) ))
End If
Which I didn't fully understand... They only planned for someone to use a numeric part number?
*Jose C Gomez*
*Software Engineer*
E: jose@...
> TextOut =
> End If
> TextOut =
> End If
