I have my second routing list set up to Documents mathing these criteria.
I have it as not in the format of *@*
however it is not recognizing them.
I tried is not equal to *@* and it printed the ones with email and scheduled non email ones to email???
--- In vantage@yahoogroups.com, "bw2868bond" <bwalker@...> wrote:
> Off the top of the head......
> 2 different Routing lists for the PO Document type
> set a filter on the Primary Email Address field if it contains @ then route through email the other where it is [Blank] route to printer
> --- In vantage@yahoogroups.com, "mmcwilliams22" <mmcwilliams22@> wrote:
> > We did our first batch of live invoicing using APM. We have it set up to email the primary email & also have an output method to print so if a receipient could not be found to email it would print. The problem I am having is it seems it is taking a blank email and assuming that is a receipient. The ones with email went fine, but the ones without did not print. Any tips on making this work the correct way?
> > We want to print all invoices to the APM printer & if they do not have an email address to print to a printer.
