I am working on a process to send RFQs via APM and attaching a spreadsheet for the vendor.
I am planning a bpm to make the file and then attach in APM. APM has an option for use stored procedure to determine supplemental docs.
Does anyone have an example stored procedure that does this? or another way to approach attaching a dynamic document in APM?
Greg Payne
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments, is privileged and confidential. It is intended only for the exclusive use of the addressee. If the reader of this message is not the intended recipient, or the employee or agent responsible for delivering it to the intended recipient, you are hereby notified that any dissemination, distribution or copying of this communication is strictly prohibited. If you have received this communication in error, please notify us at 727-578-6280 and immediately delete the communication.
Greg Payne
