I've had many battles with APM functionality. Here is what I do when
creating a new document for APM.
I send the document to APM and let it fail.
I go to the Rejected folder in APM to make sure that is where the
document ended up.
I then open the actual "reject" folder on the server. Here is our path
\\Server Name\ERMPrint\Reject
The failed document should be in here. I right click and "send to" My
Documents
I then open the DLEMFT tool on my desktop. I browse for the document
that I just sent to My Documents
Once the document is my DLEMFT tool I convert it to a Tiff document
Next I go to Doclink Administrator\Document Types and open the document
that I am trying to create.
Click on the ERM Configuration Tab and click on the Configure button.
It opens on the ERM Options tab. Make sure Input is EMF then hit the
configure button.
Click edit until you have to locate a document at which point you would
navigate to the document you had just converted into a Tiff file
Here I capture the Document Identifier. Hit OK until you are back at
the properties screen for this document.
Next click on the ERM Properties tab and capture your email and Customer
ID fields.
Click ok until you are back at the Doclink Administrator.
Now stop and restart your Doclink ERM service and resend the document.
Is this the same procedure you are following?
Blake Clemens
DMC
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf
Of Michael McWilliams
Sent: Thursday, February 12, 2009 3:47 PM
To:
Subject: [Vantage] Re: APM
Yes, I am actually only trying to Index 2 fields. One is an email
the email & the other is customer ID. They are both in the page
header of the crystal report. I put in a call to Epicor to see what
they have to say. Sometimes the APM seems so sensitive.
--- In
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ,
"Blake Clemens" <blake.clemens@...>
wrote:
> Hmm...
> I'm assuming you are generating the report out of Vantage?
> Thanks,
> Blake Clemens
> DMC
[mailto:
vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
Behalf
> Sent: Thursday, February 12, 2009 3:31 PM
> Tried that a couple times. I cannot even get a simple test word
> doc to process either. The standard forms are working fine so
> obviously I am doing something wrong.
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> "Blake Clemens" <blake.clemens@>
> wrote:
> > I would stop the ERM Service and go back and re-map all of my
> fields for
> > this document. Make sure that doclink is looking for an EMF file
> instead
> > of a text or PCL file. That should be found on the
configurations
> tab
> > of the document's properties. I have experienced funny behavior
> when
> > dealing with the PCL or text file. Does this make sense?
> > Thanks,
> > Blake Clemens
> > DMC
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
<mailto:vantage%
> Behalf
> > Sent: Thursday, February 12, 2009 2:13 PM
> > ERM file has exceeded maximum number of attempts to process.
> > wrote:
> > > If you check the properties of the failed document in the
> pending
> > folder
> > > under the Rejects tab what is the reason it gives for failing?
> > > Thanks,
> > > Blake Clemens
> > > DMC
<mailto:vantage%
40yahoogroups.com>
<mailto:vantage%
40yahoogroups.com>
> <mailto:vantage%
> > Behalf
> > > Sent: Thursday, February 12, 2009 1:49 PM
> > > I now have the new document set up & it just keeps sitting in
> > > Pending until it times out for exceeding maximum tries to
> process
> > > file. Normally if I was off in my selections it would say it
is
> > not
> > > recognized.
<mailto:vantage%
40yahoogroups.com>
> > > "Brad Ebright" <bebright@> wrote:
> > > > You have to go into the tool and convert it to a .tiff
> document.
> > > > We have a shortcut on our desktop called DLEMFTool21.exe
that
> > you
> > > use to
> > > > convert the spool files to a .tiff. Then you should be able
to
> > go
> > > into the
> > > > APM administrator and map the fields.
> > > > Let me know if you need any other help.
> > > > Thank You,
> > > > Brad Ebright
> > > > MGS Inc.
> > > > 178 Muddy Creek Church Rd.
> > > > Denver, PA 17517
> > > > (717)336-7528
> > > > _____
<mailto:vantage%
40yahoogroups.com>
> <mailto:vantage%
> 40yahoogroups.com>
<mailto:vantage%
40yahoogroups.com>
> <mailto:vantage%
> 40yahoogroups.com>
> > <mailto:vantage%
> > > Behalf Of
> > > > Michael McWilliams
> > > > Sent: Thursday, February 12, 2009 10:27 AM
<mailto:vantage%
40yahoogroups.com>
> > > > Subject: [Vantage] APM
> > > > I am trying to set up a new document for APM. I disabled my
> ERM
> > > > service, but when I print they just sit in the spool as SHD
> > SPL
> > > > files. I recall when I was setting them up before that an
> image
> > > file
> > > > should have been created. We set up our Electronic Remit. &
it
> > has
> > > > been working. Now I try to capture that with ERM & it also
> just
> > > sits
> > > > as the SHD & SPL. Its been a while did I forget a step?
> > > > [Non-text portions of this message have been removed]
