I’ve got a frustrating issue and i’ve tried multiple logic to get it to work.
I’m trying to update both an existing and copy of a dashboard layer, and when attempting to add a new panel card or modify an existing, it won’t allow any of the existing to be resized or moved when it’s in Edit Box Layout mode.
I’ve toggled fit to page mode off and on again, and all that does is move my cards back up to the top side by side and no longer able to move them back again.
Before I go down the path of re-creating the dashboard, I thought i’d check in here, as I have a few highlight rules and child-parent grids which would all need to be recreated.
We are on 25.1. I created a dashboard a few days before the problem 1 and I can move/resize the Panels. I created 1 yesterday and can move/resize the grids.
I have a ticket in as to why this particular 1 is being problem-some.
On the problemsome one I created all the Dataviews and wired up the _Get events to flow through ( using BAQ’s with Parameters because it should be a good idea ??)
