Application Studio Data Discovery Widget Date Filter
In 2025.1.11, I am working on setting up a data discovery widget inside a newly created application. After following this thread I managed to get the data discovery widget set up with a few filters.
This is the BAQ that I made for the data discovery view.
LMC-PartDemandHistory2.baq (9.9 KB)
This is the data discovery view that I made from the baq.
Part Order Quantity.json (25.8 KB)
The CustID filter works fine, but the from (date01) and to (date02) filters do not. The filters only make the data discovery show every part that has a need by date of date02. I wanted it to show every part that has a need by date between date01 and date 02. I tried this with multiple different data discovery widgets, and they all have this same issue.
Is this something that anyone else has seen? If so, is there a workaround to this?
I did some more troubleshooting, and it looks like the data discovery widget only takes in the latest input if there is more than one of a subscriber. So, if I enter in date02, then date01, it takes in only date01 and sets the need by subscriber to be date01.
Did you figure out how to use all the filters? On my end, depending on the row of the grid, it uses 1,2 or 3 filters…
Nope, not at all. I really have not gotten around to trying this again.
