For an on-prem installation, how does one turn on version history for Application Studio? I have not found any documentation that describes the correct setting beyond a vague reference to “sysconfig” (which does not seem right as this should be a server-side setting?).
From the MVP Version Control Management section of the Application Studio Fundamentals Users Guide:
Did you check Conversion Workbench ID 192…
Interesting. I would have never thought to look there. It says it was run two versions prior to the one we are running now.
That upgrade was done by Epicor.
It seems I will have to run both 191 and 192 again to take everything that is currently in the filesystem and load it into the database? If so, that sounds like a task that will have to wait until our next upgrade.
