Appservers will not start - sometimes!
Yes, we are running OpenEdge 10.0B SP05.
--- In vantage@yahoogroups.com, "peterlv2002" <peterlv2002@...> wrote:
> Have you applied OpenEdge SP5? There are issues with Window 2003 that
> cause the admserver to not respond timely to the start service command
> and that leads to appservers not firing.
> --- In vantage@yahoogroups.com, "hoomail4me" <hoomail4me@> wrote:
> > New install of Vantage v8 with three databases (mfgsys80, train80,
> > test80) and corresponding appservers (three per database).
> > When rebooting the server, most of the time, all appservers will not
> > start (auto start checked). It is not always the same appservers that
> > will not start. I CAN start manually once the server is up through
> > Progress Explorer Tool.
> > Anyone cross this bridge?
> > Thanks,
> > Bill
Bill
I have never tried to run all 3 databases at the same time. I would not recommend running more than one live database at a time. Each appserver takes a LOT of resources, and when you run all 3 appservers for 3 databases that's a LOT of overhead that you're probably not using.
I would recommend you uncheck autostart for the databases you don't need on a regular basis and manually start them when needed.
Pete
hoomail4me <hoomail4me@...> wrote: New install of Vantage v8 with three databases (mfgsys80, train80,
Bill
Get your own web address for just $1.99/1st yr. We'll help. Yahoo! Small Business.
> Thanks,
> Bill
I've had this happen before and it typically happens if the appserver port is hung up (or is perceived as in use by some other application- use netstat -a at cmd> and view results for the port number in question, if the problem is consistently occuring on one port.
I created a start all batch file script that sequentially starts each database, appservers etc. and this seemed to have resolved the issue.
> Thanks,
> Bill
