AppServers won't start
This problem has been there since we started using progress 10.1b. Progress 10.1b change the shared memory segment size to 1024kb versus 128kb.
The -B is the same as the # Blocks in DB buffer in the default configuration for the database. There is a way to increase the number of buffers up to a limit by using the -shmsegsize option in the server arguments field. I was able to get the buffers to a little of 300,000 by adding "-shmsegsize 128" to the Other server arguments field. This changes the shared memory segment size back to 128.
I have tried to increase the number of buffers with every progress patch that I have loaded with no luck and I am on patch 309. I think that is the latest patch.
----- Original Message -----
Sent: Tuesday, November 18, 2008 11:14 AM
Subject: [Vantage] Re: AppServers won't start
I am having the same error on my first attempt an 8.00.805 test
installation. Where is the -B?
Randy Weber
--- In vantage@yahoogroups.com, "vantage" <vantage@...> wrote:
> There is an old bug that limits the shared memory to the -b to
200,000 and
> are suppose to release a fix for this. I don't know if this
release was
> that fix for the old 200,000 limit but they now have another
problem. I
> have talked to support and they are starting a call with progress
on this.
> Steve
> -----Original Message-----
> From: bw2868bond [mailto:bwalker@...]
> Sent: December 18, 2007 10:17 AM
> Well, that 'fixed' it...... So even though I have the memory to
> support it, I can't load the db into memory any more??
> --- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com,
> "vantage" <vantage@> wrote:
> > I have found you can not get into the admin tools. I had to lower
> the -B
> > down below 80,000 (8K data base) to get in.
> > Steve
> > From: bw2868bond [mailto:bwalker@]
> > Sent: December 18, 2007 9:27 AM
> > To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
> > Subject: [Vantage] AppServers won't start
> > Anyone on OpenEdge 10.1b update to SP3?
> > The appservers on my test box will not start after 'update'
> > Broker Log has these entries:
> > [07/12/18@10:13:58.130-0500] P-002580 T-Main 1 --- ---
> > c:\epicor\mfgsys803\Server\logs\MfgSys803.broker.log opened.
> > [07/12/18@10:13:58.130-0500] P-002580 T-Main 1 --- --- Logging
> > level set to = 1
> > [07/12/18@10:13:58.130-0500] P-002580 T-Main 1 --- --- Log entry
> > types activated: UBroker.Basic,
> > [07/12/18@10:13:58.991-0500] P-002580 T-S-0001 1 UB ----------
> > Message from server : Startup Procedure Failed (8113)
> > [07/12/18@10:13:59.105-0500] P-002580 T-S-0001 1 UB ----------
> > IOException reading message from server : java.io.EOFException:
> pipe
> > to server broken (8117)
> > Server Log has this:
> > [07/12/18@10:13:58.877-0500] P-002684 T-002688 1 AS -- Logging
> level
> > greater than 1 must be specified either for ASPlumbing or for all
> > types by using -logginglevel. (11072)
> level
> > greater than 1 must be specified either for DB.Connects or for
all
> level
> > set to = 1
> > [07/12/18@10:13:58.877-0500] P-002684 T-002688 1 AS -- No entry
> types
> > are activated
> > [07/12/18@10:13:58.991-0500] P-002684 T-002688 1 AS -- Unable to
> > attach shared memory
> Global\sharemem.c.epicor.mfgsys803.db.mfgsys.0,
> > error 0. (1720)
> > [07/12/18@10:13:58.991-0500] P-002684 T-002688 1 AS -- Error
> > initializing the application server. (5479)
> > Any Ideas ??
> > Bernie.
Charles Carden
IT Manager
Manitex, Inc.
level set to = 1
IOException reading message from server : java.io.EOFException: pipe
[07/12/18@10:13:58.877-0500] P-002684 T-002688 1 AS -- Logging level
greater than 1 must be specified either for DB.Connects or for all
set to = 1
[07/12/18@10:13:58.877-0500] P-002684 T-002688 1 AS -- No entry types
are activated
attach shared memory Global\sharemem.c.epicor.mfgsys803.db.mfgsys.0,
error 0. (1720)
Any Ideas ??
Bernie.
I have found you can not get into the admin tools. I had to lower the -B
Steve
level set to = 1
set to = 1
are activated
error 0. (1720)
Any Ideas ??
Bernie.
the -B
> Steve
> level set to = 1
pipe
level
level
level
> set to = 1
types
> are activated
> error 0. (1720)
> Any Ideas ??
> Bernie.
There is an old bug that limits the shared memory to the -b to 200,000 and
are suppose to release a fix for this. I don't know if this release was
that fix for the old 200,000 limit but they now have another problem. I
have talked to support and they are starting a call with progress on this.
Steve
the -B
> Steve
> level set to = 1
pipe
level
level
level
> set to = 1
types
> are activated
> error 0. (1720)
> Any Ideas ??
> Bernie.
Randy Weber
200,000 and
release was
problem. I
on this.
> Steve
> the -B
> > Steve
> > level set to = 1
> pipe
> level
> level
all
> level
> > set to = 1
> types
> > are activated
> > error 0. (1720)
> > Any Ideas ??
> > Bernie.
