AR Posting Problem
Or use a guid / other random string for the group name.
*John Driggers*
*Chief Data Wrangler*
*I have an Epicor blog <http://usdoingstuff.com/>. How useful is that?*
*:: 904.404.9233
:: waffqle@...
:: http://www.usdoingstuff.com <http://www.usdoingstuff.com/>
On Mon, Jan 28, 2013 at 7:48 PM, Jose Gomez <jose@...> wrote:
> Just Create The Group First, then Adjust the BPM. Or if you are feeeling
> fancy and you are on 9x you can use a BPM DataForm to run this.
> *Jose C Gomez*
> *Software Engineer*
> *T: 904.469.1524 mobile
> E: jose@...
> http://www.josecgomez.com
> <http://www.linkedin.com/in/josecgomez> <
> http://www.facebook.com/josegomez>
> <http://www.google.com/profiles/jose.gomez> <
> http://www.twitter.com/joc85>
> <http://www.josecgomez.com/professional-resume/>
> <http://www.josecgomez.com/feed/>
> <http://www.usdoingstuff.com>
> *Quis custodiet ipsos custodes?*
> On Mon, Jan 28, 2013 at 7:41 PM, neverunmacron <neverunmacron@...
> >wrote:
> > Jose,
> > With this BPM, the group name would have to be predefined, is there a way
> > where it could be any group name as different people use different group
> > names?
> > thanks
> > jose
> > --- In vantage@yahoogroups.com, Jose Gomez wrote:
> > > Vic,
> > > There is an error in Vantage where it won't let you re-use the same
> Group
> > > ID on multiple "POST" you'll actually see the error in the error logs
> if
> > > you look. The solution is to re-name all the invoices to a new group.
> > > Because some of the invoices already posted under that batch (if you
> > search
> > > the InvcHead table you'll see more invoices with that Group ID and some
> > > with the "POSTED" flag on.
> > > If you are SQL the fix is easy, if you are progress the Fix is easy
> (do a
> > > bpm on ABC Coda Maintenance Update) LoL
> > > FOR EACH InvcHead WHERE InvcGrp='YOURGROUP' AND Posted=False
> > > Assign InvcHead.InvcGrp='YOUR NEWGROUP'
> > > END.
> > > If you are on 8x you'll have to use BufferedTableUpdate buyt its the
> same
> > > concept. Make sure you create the new group first.
> > > *Jose C Gomez*
> > > *Software Engineer*
> > > E: jose@...
> > > On Mon, Jan 28, 2013 at 2:28 PM, neverunmacron wrote:
> > > > this happens quite often to my company. Where it wont post ( we have
> > > > 8.03.409C). The only work around this we found is to transfer the
> > invoices
> > > > to a new group and then it will post. Hopes this helps
> > > > Jose
> > > > --- In vantage@yahoogroups.com, Miguel Santillan wrote:
> > > > > Conversion 10250 Unlock Posts with no JE.
> > > > > Seems like I run it every week now. Might be a 9.XX thing though.
> > > > > Miguel A. Santillan
> > > > > Compass Components, Inc.
> > > > > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
> > > > Behalf Of Vic Drecchio
> > > > > Sent: Friday, January 25, 2013 2:52 PM
> > > > > To: vantage@yahoogroups.com
> > > > > Subject: RE: [Vantage] AR Posting Problem
> > > > > Thanks, Chris. Unfortunately, not present in 8.03.
> > > > > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com ] On
> > > > Behalf Of
> > > > > Chris Robisch
> > > > > Sent: Friday, January 25, 2013 5:33 PM
> > > > > Subject: Re: [Vantage] AR Posting Problem
> > > > > Try GL\General Operations\Review Journal and see if anything comes
> > up.
> > > > > Sometimes errors happen on the posting and the Review Journal will
> > tell
> > > > you
> > > > > why. From there you can typically cancel it which will clear the
> > posting
> > > > > flag on the group. Not sure if this is available in 8.03, though.
> > > > > ----- Original Message -----
> > > > > From: "Vic Drecchio" vic.drecchio@
> > > > > To: "Vantage Yahoo" vantage@yahoogroups.com
> > > > > Sent: Friday, January 25, 2013 1:40 PM
> > > > > Subject: [Vantage] AR Posting Problem
> > > > > > (Vantage 8.03.409C)
> > > > > > Our AR clerk today went through the normal routine of cutting
> > invoices.
> > > > > She
> > > > > > retrieved the shipments from yesterday, printed the invoices and
> > edit
> > > > list
> > > > > > and then Posted the Group.
> > > > > > Usually posting takes about 2 seconds; almost instantaneous and
> we
> > only
> > > > > had
> > > > > > about a dozen invoices today.
> > > > > > Around the same time someone was having printing issues so I
> > cycled the
> > > > > > Process and Task servers.. But it appears that I cycled the
> > Process and
> > > > > Task
> > > > > > server precisely the same time this 2-second posting process
> > occurred
> > > > > (hard
> > > > > > for me to believe).
> > > > > > So, SysMon shows "Task canceled due to restart of AgentMgr
> > appserver.
> > > > Task
> > > > > > deleted due to restart of Task Agent". Maybe something caused the
> > AR
> > > > > > Posting to hang, but the logs show no errors.
> > > > > > If I open Invoice Entry and search for any Groups, her AR Group
> is
> > > > still
> > > > > > there with the dozen invoices. We did Group--Post, again, and
> > > > subsequent
> > > > > > SysMon entries show "it completed successfully" but it doesn't
> look
> > > > like
> > > > > it.
> > > > > > From the table side, there is a field in InvcGrp called
> > PostInProcess
> > > > > which
> > > > > > flags that group to be locked due to posting being in process.
> That
> > > > field
> > > > > > is set to TRUE. So the system believes posting is in process for
> > that
> > > > > > group.
> > > > > > Any conversion programs out there to fix this?
> > > > > > Or should I just delete the group and re-do the process?
> > > > > > TIA.
> > > > > > Vic
> > > > > [Non-text portions of this message have been removed]
> > > > > No virus found in this message.
> > > > > Checked by AVG - www.avg.com
> > > > > Version: 2012.0.2221 / Virus Database: 2639/5556 - Release Date:
> > 01/25/13
> > 01/25/13
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and
> http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
(Vantage 8.03.409C)
Our AR clerk today went through the normal routine of cutting invoices. She
retrieved the shipments from yesterday, printed the invoices and edit list
Usually posting takes about 2 seconds; almost instantaneous and we only had
Around the same time someone was having printing issues so I cycled the
Process and Task servers.. But it appears that I cycled the Process and Task
server precisely the same time this 2-second posting process occurred (hard
for me to believe).
So, SysMon shows "Task canceled due to restart of AgentMgr appserver. Task
deleted due to restart of Task Agent". Maybe something caused the AR
If I open Invoice Entry and search for any Groups, her AR Group is still
there with the dozen invoices. We did Group--Post, again, and subsequent
SysMon entries show "it completed successfully" but it doesn't look like it.
From the table side, there is a field in InvcGrp called PostInProcess which
flags that group to be locked due to posting being in process. That field
is set to TRUE. So the system believes posting is in process for that
group.
TIA.
Vic
Version: 2012.0.2221 / Virus Database: 2639/5556 - Release Date: 01/25/13
Try GL\General Operations\Review Journal and see if anything comes up. Sometimes errors happen on the posting and the Review Journal will tell you why. From there you can typically cancel it which will clear the posting flag on the group. Not sure if this is available in 8.03, though.
To: "Vantage Yahoo" <vantage@yahoogroups.com>
> (Vantage 8.03.409C)
> for me to believe).
> group.
> TIA.
> Vic
Chris Robisch
<mailto:vic.drecchio%40swepcotube.com> >
<mailto:vantage%40yahoogroups.com> >
> (Vantage 8.03.409C)
She
had
Task
(hard
> for me to believe).
it.
which
> group.
> TIA.
> Vic
Miguel A. Santillan
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Vic Drecchio
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
Chris Robisch
From: "Vic Drecchio" vic.drecchio@...<mailto:vic.drecchio%40swepcotube.com>
To: "Vantage Yahoo" vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>
> (Vantage 8.03.409C)
She
had
Task
(hard
> for me to believe).
it.
which
> group.
> TIA.
> Vic
Checked by AVG - www.avg.com<http://www.avg.com>
Chris, thanks. Doesn't seem to be in 8.03xxx version. Appreciate the
reply.
Chris Robisch
> (Vantage 8.03.409C)
She
had
Task
(hard
> for me to believe).
it.
which
> group.
> TIA.
> Vic
Version: 2012.0.2221 / Virus Database: 2639/5561 - Release Date: 01/27/13
No 10250 in 8.03. Sounds like what I need, however. Thanks. I'll bring
this up to Support.
Miguel Santillan
Sent: Friday, January 25, 2013 6:40 PM
Miguel A. Santillan
Behalf Of
Chris Robisch
> (Vantage 8.03.409C)
She
had
Task
(hard
> for me to believe).
it.
which
> group.
> TIA.
> Vic
Checked by AVG - www.avg.comhttp://www.avg.com>
Thought I posted this already - didn't see it show up though.
In 8.03 there is a post in process flag on the group that you can set to 0. We had to do that in the same situation, and that was based on a call with Epicor. Since we were SQL we just went at the raw data.
In E9.05 the conversion program will do the same thing as changing the raw data.
If you are seeing more problems with edit lists getting locked/hung it's because the edit lists, COS/WIP capture, and Inventory WIP Recon report read the posting rules first. There could be others than those I've mentioned. What we ended up doing was telling our groups not to run the post/edit list if someone else was doing the same -- and that's not just within the particular module. If someone was running an Inventory WIP Recon the AP person would hold off running her edit lists. It did seem to reduce the locks.
If your edit lists are getting slower and slower there could be some other problems. Our edit lists started going up to 1/2 hour and it turned out there were a couple transactions in our TranGLC with no company (how could not be determined). Once we got a one-off fix from Epicor they went back to running much quicker.
Jenn
Jenn! Thanks a bunch. I copied the db to our test environment to play with
it. I ended up deleting the invoices from the Group in AR Invoice Entry
one-by-one and then deleted the original AR Group. Created a new AR Group,
Got shipments and it finally posted normally. Finance seems to be happy, AR
Aging matches up... weird.
I saw that field, InvcGroup.PostInProcess like you described below, It was
set to 1, or TRUE, and I thought about being a maverick and just updating
that field and re-trying the posting process; so I'm glad that would have
worked!
Thanks again.
Vic
Jennifer
Sent: Monday, January 28, 2013 11:26 AM
Subject: [Vantage] Re: AR Posting Problem
data.
locks.
Jenn
Version: 2012.0.2221 / Virus Database: 2639/5563 - Release Date: 01/28/13
this happens quite often to my company. Where it wont post ( we have 8.03.409C). The only work around this we found is to transfer the invoices to a new group and then it will post. Hopes this helps
Jose
> Miguel A. Santillan
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com ] On Behalf Of
> Chris Robisch
> > (Vantage 8.03.409C)
> She
> had
> Task
> (hard
> > for me to believe).
> it.
> which
> > group.
> > TIA.
> > Vic
Vic,
There is an error in Vantage where it won't let you re-use the same Group
ID on multiple "POST" you'll actually see the error in the error logs if
Because some of the invoices already posted under that batch (if you search
If you are SQL the fix is easy, if you are progress the Fix is easy (do a
END.
If you are on 8x you'll have to use BufferedTableUpdate buyt its the same
*Jose C Gomez*
*Software Engineer*
E: jose@...
> Jose
> > Miguel A. Santillan
> Behalf Of
> > Chris Robisch
> you
> > > (Vantage 8.03.409C)
> > She
> list
> > had
> > Task
> > (hard
> > > for me to believe).
> Task
> still
> subsequent
> like
> > it.
> > which
> field
> > > group.
> > > TIA.
> > > Vic
Jose,
With this BPM, the group name would have to be predefined, is there a way where it could be any group name as different people use different group names?
thanks
jose
> Vic,
> END.
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Jose
> > > Miguel A. Santillan
> > Behalf Of
> > > Chris Robisch
> > you
> > > > (Vantage 8.03.409C)
> > > She
> > list
> > > had
> > > Task
> > > (hard
> > > > for me to believe).
> > Task
> > still
> > subsequent
> > like
> > > it.
> > > which
> > field
> > > > group.
> > > > TIA.
> > > > Vic
*Jose C Gomez*
*Software Engineer*
E: jose@...
On Mon, Jan 28, 2013 at 7:41 PM, neverunmacron <neverunmacron@...>wrote:
> Jose,
> names?
> thanks
> jose
> > Vic,
> search
> > END.
> > *Jose C Gomez*
> > *Software Engineer*
> > E: jose@...
> invoices
> > > Jose
> > > > Miguel A. Santillan
> > > Behalf Of
> > > > Chris Robisch
> up.
> tell
> > > you
> posting
> > > > > (Vantage 8.03.409C)
> invoices.
> > > > She
> edit
> > > list
> only
> > > > had
> cycled the
> Process and
> > > > Task
> occurred
> > > > (hard
> > > > > for me to believe).
> appserver.
> > > Task
> AR
> > > still
> > > subsequent
> > > like
> > > > it.
> PostInProcess
> > > > which
> > > field
> that
> > > > > group.
> > > > > TIA.
> > > > > Vic
> 01/25/13
> 01/25/13
