Are 3 business days enough to test a patch when hosted in the cloud?
Patching the cloud on a Tuesday night means I get Wednesday morning to run my tests to see if anything is broken. Wednesday afternoon create a support ticket. That gives Epicor 2 days to acknowledge the ticket, then assign someone. Then start the back and forth work on duplicating or further explaining the issue. I would like to see a minimum of 5 business days. I don’t track the exact amount of idle time between steps but 2 days to work thru an issue doesn’t seam realistic or are these minor patches not worth the worry?
I hope so, as we’ve done zero testing for them for the past 7 years.
In my experience, the minor patches are welcome and the cadence is appreciated. With 2024.2 , much was broken with the .2 release and the minor patches are making the system more stable. I see less need to test every update, but increasingly (especially with 2024.2) the need to spend more time testing releases.
As others mentioned, the point updates are usually fine (knocks on wood). It’s the major updates that need a good look over.
This holds true for lots of software! The three-number version pattern (ie, 2024.2.4 or Version.Patch.Fix) gets drilled in as (Eventually.Always.Only if we have to).
“Are 3 business days enough to test a patch”. Nope. Good thing they tell us not to bother. What could go wrong?
Thanks for the feedback,
I’m going to just do simple testing. Printing daily forms. Quotes, Quote Worksheet, Traveler, PO, PS, BOL, Invoice, Timephase rpt, Scheduling Rpts.
I don’t like Monday morning fireworks, will sleep better Sunday night.
That’s prudent and should suffice.
