Assembly Dashboards with BAQ Parameters
What I did is use a BPM form and call it on the Get list and then read those values on the post process and it works.
Thanks a lot ,
Jaime
Hi all ,
 I got a BAQ that has three parameters which I need for some calculation . This works perfectly in a normal Dashboard (not updatable) but when I deploy it as an assembly the parameter table seems empty. I am checking on the BAQ directive.
Do you know if this works at all on the Updatable dashboards or how can I sent parameters to a BAQ.
Best regards,
Jaime
#ygrps-yiv-1124612387 {font-family:'Times New Roman';font-size:13px;}
I have not done this, but have you tried to set a preprocess BPM directive on get list to fill in the parameter table using code?
HTH,
Tanner
On Tue, 26 May 2015 14:08:17 -0500, jaime.hdzm@... [vantage] <vantage@yahoogroups.com> wrote:
<div id="ygrps-yiv-1124612387ygrp-text">
  <p><span>Hi all ,</span></p><p><span><br></span></p><p><span>&nbsp;I got a BAQ that has three parameters which I need for some calculation . This works perfectly in a normal Dashboard (not updatable) but when I deploy it as an assembly the parameter table seems empty. I am checking on the BAQ directive.</span></p><p><span style="word-spacing:normal;"><br></span></p><p><span style="word-spacing:normal;">Do you know if this works at all on the Updatable dashboards or how can I sent parameters to a BAQ.</span></p><p><span style="word-spacing:normal;"><br></span></p><p>Best regards,</p><p><br></p><p>Jaime</p>
</div>
<div style="color:#fff;height:0;"></div>
Using Opera's mail client: http://www.opera.com/mail/
