Assigning an Inspector
As with any inspection operation, you should be able to assign an inspector using the drop down inspector list.
As to the type of inspection required, that would be a business process question.
If the receipt is an outside process, the job traveler should indicate the type of receiving inspection.
If the receipt is a material, the PO should indicate what the receiving process should be.
Charlie Smith
ESSNER Manufacturing, L.P.
6651 Will Rogers Blvd.
Fort Worth, TX 76140
csmith@...<mailto:csmith@...>
ph: (817) 529-6165
fx: (817) 568-2625
[LOGO_Essner_Manufacturing]
Sent: Thursday, April 2, 2015 12:23 PM
Subject: [Vantage] Assigning an Inspector
We are using 9.05.603. In the inspection processing application there is the option to search by inspector ID (a drop-down box). How do you assign an inspector to a receipt inspection? We need to be able to let them know what kind of inspection we need, just regular or is the material needs to be tested by the lab.
