Ok, I have figured out how to get a file attached. However it
attaches the incorrect file name. Here is the modified code:
find xfileattch where xfileattch.company = quotehed.company
and xfileattch.key1 = string(quotehed.quotenum)
and xfileattch.relatedtofile = "QUOTEHED"
and xfileattch.attachnum = 5
no-lock no-error.
if not available xfileattch then do:
create xfileattch.
assign xfileattch.company = quotehed.company
xfileattch.key2 = ""
xfileattch.key3 = ""
xfileattch.key4 = ""
xfileattch.key5 = ""
xfileattch.relatedtofile = "QUOTEHED":U
xfileattch.attachnum = 5.
create xfileref.
assign xfileref.company = quotehed.company
xfileref.xfilename = Outname
xfileref.xfiledesc = "RTF Quote File":U.
end.
--- In vantage@yahoogroups.com, "mwliquidhappy" <liquidhappy@...>
no-lock no-error.
create xfileattch.
create xfileref.
end.
wrote:
> I have noticed that while running tracing and creating an
> that it seems to create a table called "quotehedattch". I havethrough
> modified my code to go like this:
> find quotehedattch where quotehedattch.company = quotehed.company
> and quotehedattch.quotenum = string(quotehed.quotenum) no-lock no-
> error.
> if not available quotehedattch then do:
> create quotehedattch.
> assign quotehedattch.company = quotehed.company
> quotehedattch.quotenum = quotehed.quotenum
> quotehedattch.drawingseq = 0
> quotehedattch.xfilerefnum = 0
> quotehedattch.drawdesc = quotehedattch.quotenum + ".rtf"
> quotehedattch.filename = outname.
> end.
> but it doesn't work. Am I missing something?
> --- In vantage@yahoogroups.com, "Stan Chmura" <schmura@> wrote:
> > In 6.1 I have attached pdf's (and other documents) to quotes
> > Document Association. To do this, first you'll need the stringfor
> theView
> > print and view commands in Document Association set up. That
> you'll find in
> > system Management/Configuration maintenance . For pdf's it is:
> > AcroRd32.exe "&1" and Print is AcroRd32.exe /p "&1". Then on thea
> quote,
> > each line has a Doc. Assoc. icon in the upper right corner. Just
> update the
> > line and click on the icon to add the path to the document.
> > _____
> > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On
> Behalf Of
> > mwliquidhappy
> > Sent: Friday, May 18, 2007 11:20 AM
> > Subject: [Vantage] Attaching a Document to a Quote
> > I am trying to figure out how I can write progress code to attach
> > document to a quote. Has anyone done this before that would havea
> > code snippet or be able to tell me how to code this?
> > Thanks!
