I think I got this tip from here.....I use f:\foldername\.\
Slash Dot Slash at the end of the folder name
Hth,
Linda
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Bethany Rye
Sent: July-05-12 3:16 PM
Subject: RE: [Vantage] Attaching a file folder to a job - 9.04.507A - SQL
Thank, Brian. I have it mostly working. It's a little clunky but something
we can work with for now. Guess I missed the post last month.
Beth
Beth Rye
IT Director
CIGNYS
Email: <mailto:brye@...<mailto:brye%40cignys.com>> brye@...<mailto:brye%40cignys.com>
***ITAR NOTICE***
This e-mail and/or the attached documents may contain technical data within
the definition of the International Traffic in Arms regulations, and are
subject to the export control laws of the US Government. Transfer of this
data by any means to a foreign person, whether in the US or abroad, without
an export license or other approval from the US Department of State, is
prohibited. No portion of this e-mail or its attachment(s) may be reproduced
without written consent of CIGNYS. If you are not the intended recipient or
believe that you may have received this document in error, please notify the
sender and delete this e-mail and any attachments immediately.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of
Brian Roberts
Sent: Thursday, July 05, 2012 11:13 AM
I just answered this last month... here you go for 9.05, should work in
9.04.
Brian.
Yes, but not easily. It worked better in Vantage 6, its possible but a
multi-step process in 9.05.
Create a new Document Association with extension \ (yes, just a
backslash) and view command of: explorer.exe "&1"
Attach a single document in the folder you want - it will create a link
to eg X:\Stuff\whatever.PDF
In External File Reference, find that link (it will be the highest#) and
change the filename to X:\Stuff\
Now opening that attachment will open windows explorer right at that
folder.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com> ] On
Behalf
Of Bethany Rye
Sent: Thursday, July 05, 2012 11:03 AM
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> <mailto:vantage%40yahoogroups.com>
SQL
Thanks for the suggestion. That would work if files were all in the
folder
at one time, but unfortunately, the folder I want to attach will be
holding
all kinds of files that will be added continuously throughout the life
of
the job and may have some added after the job finishes. What would be
ideal
is if the link could be to open the folder instead of just a file.
Now that I'm thinking about this, maybe what needs to happen is that the
folder is zipped and then if a file gets added to the folder, the person
then has to re-zip the folder. I might try this.
Behalf Of
Vic Drecchio
Sent: Thursday, July 05, 2012 10:52 AM
SQL
When I've needed to attach a dozen or so files to something, I zip them
into
one file and then attach.
Behalf Of
Bethany Rye
Sent: Thursday, July 05, 2012 10:12 AM
Subject: [Vantage] Attaching a file folder to a job - 9.04.507A - SQL
I am having difficulty with attachments. I know how to attach a document
to
a job, such as an excel spreadsheet, but I cannot figure out how to
attach a
whole file folder to the job (not just one document). Has anyone done
this?
Can it be done? If so, how is it done?
Beth
Beth Rye
IT Director
CIGNYS
Email: <mailto:brye@...<mailto:brye%40cignys.com> <mailto:brye%40cignys.com>
<mailto:brye%40cignys.com> > brye@...<mailto:brye%40cignys.com> <mailto:brye%40cignys.com>
***ITAR NOTICE***
within
this
without
reproduced
or
the
No virus found in this message.
Checked by AVG - www.avg.com
Version: 2012.0.2193 / Virus Database: 2437/5112 - Release Date:
07/05/12
07/05/12
Hth,
Linda
Beth
Beth Rye
IT Director
CIGNYS
***ITAR NOTICE***
Brian Roberts
9.04.
Brian.
folder.
Behalf
Of Bethany Rye
SQL
folder
holding
of
ideal
Behalf Of
Vic Drecchio
SQL
into
Behalf Of
Bethany Rye
to
attach a
this?
Beth
Beth Rye
IT Director
CIGNYS
***ITAR NOTICE***
within
this
without
reproduced
or
the
07/05/12
07/05/12
