Attaching a UD Table to the Job Oper table
Hello all,
I am getting the exact error above as well when trying to add UD01 to the Job Entry screen.  It's happening when you SetParentView in the InitializeUD01Adapter Sub.  Specifically:
Me._edvUD01.SetParentView(Me._edvJobHead, parentKeyFields, childKeyFields)
I've had this exact code in SerialNo Maintenance and Customer Maintenance and did not get the error.  Maybe the issue is JobEntry specific?  Full code below, anyone have a hunch?
Private Sub InitializeUD01Adapter()
Me._ud01Adapter = New UD01Adapter(Me.oTrans)
Me._ud01Adapter.BOConnect
Me._edvUD01 = New EpiDataView
Me._edvUD01.dataView = New DataView(Me._ud01Adapter.UD01Data.UD01)
Me._edvUD01.AddEnabled = true
Me._edvUD01.AddText = "New UD01"
If (Me.oTrans.EpiDataViews.ContainsKey("UD01View") = false) Then
Me.oTrans.Add("UD01View", Me._edvUD01)
End If
' Initialize EpiDataView field.
Me._edvJobHead = CType(Me.oTrans.EpiDataViews("JobHead"),EpiDataView)
' Set the parent view / keys for UD child view
Dim parentKeyFields(0) As String
Dim childKeyFields(0) As String
parentKeyFields(0) = "JobNum"
childKeyFields(0) = "Key1"
If (Not (Me.oTrans.PrimaryAdapter) Is Nothing) Then
' Me.oTrans.PrimaryAdapter.GetCurrentDataSet(Epicor.Mfg.UI.Searches.DataSetMode.RowsDataSet).Tables.Add(Me._edvUD01.dataView.Table.Clone)
End If
Dim ja As JobEntryAdapter = oTrans.JobEntryAdapter
dtUD01 = _edvUD01.dataView.Table.Clone()
ja.JobEntryData.Tables.Add(dtUD01)
End Sub
Hi All,
I have been trying to figure out a way to link a UD table to the Job Oper table so that I can have access to more custom fields as well as the ability to update those fields regardless of a job being released. Have any of you tried linking a UD table to the Job Oper table (or any other table) and have some advice/instructions for how to do it?
-Marcus S.
marcus@...
Just use the Wizard in Customization mode. Its in the Actions or Tool Menu ("Add Child UD Table")
Jose C Gomez
Software Engineer
T: 904.469.1524 mobile
On Tue, Nov 18, 2014 at 1:01 PM, marcus@... [vantage] <vantage@yahoogroups.com> wrote:
Â
<div>
  <p></p><p><span>Hi All,</span></p><p><span><br></span></p><p><span>I have been trying to figure out a way to link a UD table to the Job Oper table so that I can have access to more custom fields as well as the ability to update those fields regardless of a job being released. Have any of you tried linking a UD table to the Job Oper table (or any other table) and have some advice/instructions for how to do it?</span></p><p><span><br></span></p><p><span>Thanks,</span></p><p><span>-Marcus S.</span></p><p><span><a rel="nofollow" target="_blank" href="mailto:marcus@...">marcus@...</a></span></p><p></p>
</div>
<div style="color:#fff;min-height:0;"></div>
I am getting the following error after I run through the wizard:
Error Detail
Must set Static Filter before setting Parent/Child relations
Stack Trace
   at Epicor.Mfg.UI.FrameWork.EpiDataView.set_StaticFilter(String value)
   at Epicor.Mfg.UI.FrameWork.JobLib.JobTransactionHelper.SetViewFilters(String job, Int32 AssemblySeq)
   at Epicor.Mfg.UI.App.JobEntry.Transaction.SetViewFilters(String job, Int32 AssemblySeq)
   at Epicor.Mfg.UI.App.JobEntry.Transaction.GetByID(String jobNum)
Any ideas?
