Attachment Events
That is a good idea. Thanks, Jeff.
Ross
--- In vantage@yahoogroups.com, "Jeff Greenaway" <vantagegroup@...> wrote:
> Companies I've worked with have generally found the direction John suggested
> to work well.
> Instead of trying to drive the security from the retrieval side, we set it
> up on the initial storage side. When the file that will become an
> attachment is created, it is stored in a directory location with permissions
> appropriate for that type of attachment. It leverages the network
> permissions they already have to maintain and means they didn't have to
> build something in Vantage.
> It does require planning it out in advance, so figuring out a standard set
> of subfolders for each project could reduce the administration time. In
> your situation, each time a new project is created, the standard subfolders
> (and permissions) would be set up, ready for attachments to be dropped in.
> When users go to open an attachment, the permissions are already in place.
> It helps greatly if your network security groups mirror your Vantage
> security groups.
> Regards,
> Jeff
> Jeff Greenaway
> Consulting CIO/ERP Consultant
> jeffgreenaway@...
> www.cio-ondemand.com
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> rossh777
> Sent: Thursday, October 04, 2012 2:43 PM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Re: Attachment Events
> Thanks, John.
> I did write up a script that will change file/directory permissions on the
> fly but I am trying to avoid that so they don't get stepped on in the
> future.
> The solution will add documents from a dropdown box, as well as let people
> add attachments through the native method, and it auto-copies to a common
> location, creates project id subfolders, etc. Some of the files need
> different security and I was hoping to do it 'behind the scenes' without
> pushing the attachment variations to the user.
> Thanks again,
> Ross
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> , John
> Driggers <waffqle@> wrote:
> > I don't think it uses a BO to do that. You may be able to wire up a
> handler
> > for one of the grid events. It would probably be cumbersome though and it
> > would need to be repeated for every form.
> > Maybe you could set directory permissions on the share where you're
> storing
> > the docs?
> > *John Driggers*
> > *Chief Data Wrangler*
> > *I have an Epicor blog <http://usdoingstuff.com/>. How useful is that?*
> > *:: 904.404.9233
> > :: waffqle@
> > :: http://www.usdoingstuff.com <http://www.usdoingstuff.com/>
> > On Thu, Oct 4, 2012 at 5:03 PM, rossh777 <ross.hughes3@> wrote:
> > > 8.03.409C
> > > Has anybody ever applied vantage level security to opening attachments?
> I
> > > am trying to do some security group checking, but when I double-click an
> > > attachment I can't get any adapter to return a method, etc. to hook in
> to.
> > > Ideally, what I would like to do is check if the vantage user is in a
> > > security group before allowing them to open the attachment.
> > > Is this possible?
> > > Thanks,
> > > Ross
8.03.409C
Has anybody ever applied vantage level security to opening attachments? I am trying to do some security group checking, but when I double-click an attachment I can't get any adapter to return a method, etc. to hook in to.
Ideally, what I would like to do is check if the vantage user is in a security group before allowing them to open the attachment.
Is this possible?
Ross
I don't think it uses a BO to do that. You may be able to wire up a handler
Maybe you could set directory permissions on the share where you're storing
the docs?
*John Driggers*
*:: 904.404.9233
:: waffqle@...
On Thu, Oct 4, 2012 at 5:03 PM, rossh777 <ross.hughes3@...> wrote:
> 8.03.409C
> Is this possible?
> Thanks,
> Ross
Thanks, John.
I did write up a script that will change file/directory permissions on the fly but I am trying to avoid that so they don't get stepped on in the future.
The solution will add documents from a dropdown box, as well as let people add attachments through the native method, and it auto-copies to a common location, creates project id subfolders, etc. Some of the files need different security and I was hoping to do it 'behind the scenes' without pushing the attachment variations to the user.
Thanks again,
Ross
> the docs?
> *John Driggers*
> *:: 904.404.9233
> :: waffqle@...
> > 8.03.409C
> > Is this possible?
> > Thanks,
> > Ross
to work well.
security groups.
Regards,
Jeff
Jeff Greenaway
jeffgreenaway@...
rossh777
Thanks, John.
future.
Thanks again,
Ross
handler
storing
> the docs?
> *John Driggers*
> *:: 904.404.9233
> :: waffqle@...
> > 8.03.409C
I
to.
> > Is this possible?
> > Thanks,
> > Ross
