Hello Mark
Yes v8.03 is correct
I see what you are explaining but, I am a little confused (sorry).
The goal for me would be to add this field and pull the data in from
an Order already entered into the system.
This data exsists before the shipment, (entered during Order Entry).
I would like to create this field for View info ONLY in the "Enter
Customer Shipment" and afterwards print it out in the Packing Slip
What do I need to do to get this field to do a lookup?
-Joe
-Joe
>on the
> (Assuming V8 here...)
> If you go to the Data Dictionary and look up ShipDtl, you can click
> "Show VB Fields" box and you'll see all of the user-defined fieldsavailable
> to you. You can use Number01-Number10 for you POLine.you'll create a
> If you plan to add this data at Ship time and not Order Entry,
> customization of the Enter Customer Shipment by adding a text fieldto the
> screen and binding it to ShipDtl and Number01 (or whatever fieldyou choose).
>Packing Slips,
> To print, you'll need to go into the Report Data Definition for
> go to the Exclude Tab and add Number01 (or whatever).
> Modify your Packing Slip and you're good to go.
> Mark W.
