Hi Experts…
I have created some working auto allocations BPM’s that work ok when you have the plant context set up and correct as per the sales order you are trying to auto allocate. It fails when you are not in the same plant as the SO. The initial call to GetList in the OrderAlloc BO returns nothing based on the mismatch of plants. I have also moved the code to a Function and get the same result.
Has anyone got a solution or tip in this area they can share?
thx Steve
