Auto-fill field immediately after making dropdown selection
I’m trying to automatically fill the Tracking Number field in Customer Shipment Entry immediately following a selection in the Ship Via list.
Currently, I have an in-transaction Data Directive doing this, but the Tracking Number field does not immediately populate upon making the selection; the user has to Save first, then the Tracking Number field populates appropriately.
The value that should populate the Tracking Number field is stored in a UD field of the ShipVia table.
For context, several of our shipment methods do not have associated tracking information available (such as Will Call, Our Truck, etc.) but we still want a message to display on the automatic shipment notification email that is sent. These custom messages are things like, “Your order is ready for pickup.”
I feel like the answer is through customizing the Cust. Shipment Entry form with some kind of event, but the Event Wizard doesn’t allow me to access native fields.
How can I have the custom ShipVia message auto-populate the Tracking Number field as soon as the ShipVia selection is made?
Here is my current setup:
Here is my code:
var shipHead = ttShipHead.FirstOrDefault();
var shipVia = shipHead.ShipViaCode;
string trackingMsg = Db.ShipVia.Where(t => t.Company == Session.CompanyID && t.ShipViaCode == shipVia).FirstOrDefault().TrackingMsg_c;
var trackingNum = "";
if (!string.IsNullOrEmpty(shipVia))
    switch (shipVia)
        case "BG":
            trackingNum = trackingMsg;
            break;
        case "CONT":
            break;
        case "INTE":
            break;
        case "NA":
            break;
        case "L&J":
            break;
        case "PULV":
            break;
        case "ST":
            break;
        case "VEND":
            break;
        case "WILL":
            break;
        default:
            trackingNum = string.Empty;
            break;
// To use in Test Messages
callContextBpmData.Character01 = shipVia;
callContextBpmData.Character02 = trackingNum;
callContextBpmData.Character03 = trackingMsg;
shipHead.TrackingNumber = trackingMsg;
Not sure what you mean by the Event Wizard
Are you doing this in classic or Kinetic?
Did you do a trace (does EPicor invoke a BO when the SHip Via Code Changes)
If so, you can piggy back of that BO call
If not and its classic you can subscribe to a column changing event in the adapter and then lookup / set the appropriate value in the DataView
If its in Kinetic same rules apply, you can use a column changing trigger to do the appropriatre lookup
Sorry for the lack of clarity.
We’re in Classic on 10.2.700. This is what I meant by the Event Wizard:
I did start by doing a trace when changing the ShipVia, but nothing at all was called.
Thank you for the suggestion about the column changing event. I will give that a whirl and report back.
