Thanks for the replies. We ended up using a date + time function in
Crystal.
Kelly
Crystal.
Kelly
--- In vantage@yahoogroups.com, Dan Shallbetter <dans@s...> wrote:
> Kelly,
> If your serial numbers can be random I would use a time function in
Crystal.
> If they need to be sequential.you might want to look at creating a
parameter
> field using discrete values and using the import pick list feature.
This
> would still require keeping track of the next number to use.
> Good luck.
> Dan Shallbetter
> States Electric Mfg.
> -----Original Message-----
> From: Kelly Wendorff [mailto:kelly.wendorff@s...]
> Sent: Thursday, April 01, 2004 2:36 PM
> To: 'vantage@yahoogroups.com'
> Subject: [Vantage] Auto-Increment in Crystal
> Greetings,
> I am modifying the crystal form Shiplabl.rpt. Currently, we enter
the
> required data into a 3rd party software - I want to use "shipping
labels"
> and have crystal pull the required fields.
> One of our customers requires a unique serial number on each label.
The
> only requirement is that it is unique, right now shipping is using a
5 digit
> number and increasing it by one (# + 1) each time they print.
> There must be a way to auto-increment this field in Crystal each
time we
> print...
> Any Crystal Guru's willing to help?
> TIA!
> Kelly Wendorff
> Cost Accounting Manager
> SteelCraft Corporation
> 105 SteelCraft Drive
> Hartford, WI 53027
> 262.673.6770
> 262.673.4380 (Fax)
> www.scc-wi.com
