Auto Job Completion/Close
We have been testing a BPM instead because of all the different issues we have with the process. We can complete and close the jobs and also purge dollars from WIP to COS. The final step we need to do is clear WIP locations, have not figured this one out but I am assuming I just find the correct PartWip record and delete.
--- In vantage@yahoogroups.com, "Stan Chmura" <schmura@...> wrote:
> I have only tried this in test environment of 8.03.400 but one of the things
> I found that made it unusable for me was that the final operation has to
> have cost associated with it. Otherwise the job will not complete. All of
> my methods masters has the last operation set up as qty only because we use
> it just as a tool to indicate that the job is complete and is now a
> candidate for closing. I contacted Epicor about this and the workaround was
> to enter a $.01 cost for the operation. As I said above I tested this in
> 8.03 and don't know if it has been changed in later releases o V8 or V9.
> Hope this helps!
> Stan
> _____
> From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of
> jmpratt7
> Sent: Thursday, August 27, 2009 8:43 AM
> To: vantage@yahoogroups.com
> Subject: [Vantage] Auto Job Completion/Close
> Does anyone use this functionality and find it beneficial overall? If so,
> please provide some detail about how you use it.
> Thanks,
> Jim Pratt
> Vantage 8.03.404B
Does anyone use this functionality and find it beneficial overall? If so, please provide some detail about how you use it.
Jim Pratt
Vantage 8.03.404B
Hope this helps!
Stan
_____
jmpratt7
Jim Pratt
Vantage 8.03.404B
